Chuck Thoits
- NH
I like quick
Ok i like fixing things but is this project not costing too much in toxic materials and time.
Surely by now you could have remade the shutters especially with your skill and setup.
I had to strip paint off porch ballusters I had pulled off, maybe 20 yrs ago now. I found a propane torch the quickest way to remove the paint, then sand , prime and top coat. Not sure if it's a safe way, with old lead paint.
Would using a mask for spray painting protect from those fumes when using a torch or heat gun?Have to chime in on this one....
Lead oxide (the stuff used in paint) vaporizes at around 425C.
Your standard heat gun operates around 540C. A propane torch can reach nearly 2000C.
Lead is toxic to people at all ages, not just children. Using torches, heat guns, & sanders on lead paint is dangerous.
Maybe I'm crazy but it almost seems easier to make new ones
That's a ton of work left to do Chuck.
Noe that brings up yet another question.
If I cut down a 200 year old tree and make shutters out of it are they antiques?
