Results 1 to 10 of 15
Thread: How to turn a tool handle?
    13,361
    With my relative success in making the ember rake last week (The rake I made I used 1/2" stock which was too heavy), I thought I might go ahead and make a set of tools for the fireplace (Ember Rake, Poker, Shovel).
    But I don't think I really did it the right way. The end of the handle I really didn't finish off very well.
    Can anyone point me in the right direction to turn a tool handle? Since I'll be turning 3 of them, I thought it might make sense to do it the right way.
    I did prepare 5 blanks today, so hopefully I can get 3 good handles. This time I'll use 3/8" steel and make each tool 30" from base to tip.
    Thanks in advance for your help!
    Aug 2008
    Reno, Nv
    3,632
    Hey Brent!
    1st...your ember rake was great!!
    2nd...Do you routinely make turning tool handles?
    3rd...Do you know...or have you ever owned a turning handle you felt to be superior to whatever it was that you made...and do you have said proof in your hand at this moment??
    Case dismissed!!
    Chances are that it was made from end-grain fiber...good luck making that look pretty A lot of sanding s involved and usually some bad words...coffee ingestion and LOML comments not in favor of or work
    Jul 2007
    DSM, IA
    5,719
    Here's a good tutorial from Thompson Lathe Tools...
    >>>link<<<
    My Website
    13,361
    Thanks Jeff!
    That all makes sense but I feel like I'm doing something wrong when I get to the final step of parting end of the handle off of the blank.
    I'd like to get a perfectly smooth rounded end to the tool, but as I start to work it down, it usually breaks off before I finish. Then I have to move to sanding the end of it by hand with sandpaper. Or is that the normal way to do it?
    13,451
    Are you using a steady rest to keep it from getting off center?
    S E Washington State
    3,777
    I agree with Darren, I think to get a great finish on th end you would find it worth while to make a little steady rest. The other option is to do what I do and hold it towards the unsupported end with one had and sand with the other as the lathe is on, a slow speed.
    "We the People ......"
    13,361
    No steady rest. Would that help for something like this?
    Hmm, Might have to review the archives and put something together...
    13,451
    Jim Bradley just wrote up an article for building one...
    http://familywoodworking.org/forums/...ht=steady+rest
    Hint: Hit the thrift store and look for some used roller blades for donor wheels.
    Oct 2009
    Harrisburg, NC
    140
    I haven’t turned a lot of handles but when I did, I drilled and turned the ferrule end first. Then it was held with a cone in the tailstock. When parting off (next to the headstock) you may try using a skew, making V cuts, and then slowly rounding it over. You should get a very smooth finish (quite unlike using a parting tool). Do not part off exactly at the end or you may get a divot in the wood. Bring it down to about 1/8 inch or less and leave a little stub attached to the wood. You can then cut off the stub with a chisel or pocketknife and it takes very little sanding.
    Some people also use an upholstery tack in the end but others think this is cheating.
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    13,361
    That makes sense. Guess I've got to get the skew out again and practice with it a bit...
    Thanks!
  1. Getting Started - Tool Handle Styles
    By Lora Irish in forum Carving
    Last Post: 11-21-2014, 03:14 PM
  2. New pens and tool handle
    By Terry Quiram in forum Lathe Project Showcase
    Last Post: 11-08-2014, 09:30 PM
  3. Options for Tool Handle?
    Last Post: 07-15-2013, 01:43 PM
  4. How to turn a Hammer Handle??
    By Keith Palmer in forum General Woodturning Q&A
    Last Post: 12-24-2008, 06:25 PM
  5. Tool Handle Finish
    By Travis Johnson in forum Finishing School
    Last Post: 03-09-2008, 10:36 PM
