Results 1 to 5 of 5
Thread: Chop Saw Question ???
    Palm Springs, Ca
    1,169
    I got out a chop saw I have today and tried to figure out how to put the blade on it. I am either missing a pc to it or Im not seeing how it goes together. The bolt is loose in the hole of any of the metal blades there are. I took it to the hardware store and slipped the bolt thru the hole in the other blades and it is smaller than the diameter of the hole in the blade............
    Anybody think of anything or am i missing a pc to it ????
    Thanks Dan
    Attached Thumbnails Attached Thumbnails Chop-1.jpg   Chop-2.jpg   Chop-3.jpg   Chop-4.jpg   Chop-6.jpg
    Dec 2008
    Santa Claus, In
    4,779
    Missing a bushing maybe? Maybe a special size hole in the blade? Google the model and see what comes up.
    Dec 2008
    Portland, Oregon
    1,898
    Dan,
    Mine is a Dewalt, but this is how it works.
    The motor shaft is aprox " diameter
    There is a steel spacer washer - inside dia, 1" outside dia.
    The blade has a 1" hole fits over the spacer washer.
    Hope this helps
    Jesus was a Woodworker
    Honolulu, Hawaii
    1,103
    Dan Mosley,
    I have one of those with a broken handle. Motor, gears, etc, all good shape.)
    You can have it, or anything from it you need. I will try to get it out of storage this week, if that is soon enough?
    Dan Mooney, I think you are talking about a miter saw, and Dan Mosley has a metal chop saw.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Palm Springs, Ca
    1,169
    Ok Tony and thanks.............
  1. Portable chop saw stand
    By Virgil Huffman in forum Jigs and Fixtures
    Last Post: 12-31-2009, 11:29 PM
  2. chop saw stand?
    By Virgil Huffman in forum New Tools
    Last Post: 03-16-2008, 04:25 PM
  3. chop saw stand?
    By Virgil Huffman in forum Carpentry and Construction
    Last Post: 03-15-2008, 10:42 AM
  4. Chop Chop, also
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 10-17-2007, 03:30 PM
  5. Chop Chop!
    Last Post: 10-16-2007, 03:03 AM
