Results 1 to 10 of 19
Thread: Router Table/ Speed Adjustment
    Dec 2008
    Santa Claus, In
    4,779
    Hey, quick question. For those with router tables, how do you adjust your router speed? Open the door and turn the knob or external switch?
    Seeing as I can't really build anything right now, I am working up plans and specs. Helps to keep my head straight.
    5,323
    My Hitachi M12V has the speed control in a very awkward place to get to under the table. Changing speeds on it is not fun, but I can't think of any other way to do it.
    BTW, on a variable speed router, you're not supposed to use an external speed control - I guess they fight each other, or something.
    As for those external models, I've had two of them, and neither one worked well. The motors kept surging, rather than holding a steady speed. My wife does use one of them on the high-speed bobbin winder for her quilting machine, though.
    Dec 2008
    Santa Claus, In
    4,779
    Yea, that's what I was thinking Jim. You can't use a controller on a variable. Got to be a better way.
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    that was what I was going to say about the speed control not working on routers that come with speed controls. My older PC works with a variable control that I picked up at Grizzly but the new one only goes off and on. I have to lift the lid and change the speed directly on the machine if I wanted to change speeds.
    May 2009
    Syracuse, Nebraska
    669
    My PC has an easy to reach adjust but that model isn't made anymore. Gonna start hitting the pawn shops to see if I can find another one or two........or more.
    ha this is easy, just have a router table for each speed ...
    but really, I pick the insert up out of the table with the router attached and move the little knob. Be glad you dont have a shaper and have to crawl underneath to move the belt on the pulleys
    I cant remember where I saw it but I saw a tutorial of how to add an external speed knob to a milwuakee router, Ill see if I can find it
    3,135
    I have a Hitachi M12V that was well used when I received it & the speed control was shot, it is wired to just on & off with the switch & I use a external speed control with it & it works ok in my router table.
    5,323
    Quote Originally Posted by Eric Roberts View Post
    ...but really, I pick the insert up out of the table with the router attached and move the little knob...
    That's great - if you have an insert.
    My router is bolted directly to the underside of my Corian® top.
    Dec 2008
    Santa Claus, In
    4,779
    Well I found this, but it ain't happenin
    http://www.amazon.com/JessEm-05626-M...059305&sr=1-41
    13,366
    You got any pics of that? I'm not 100% happy with my router table top. It's only two layers of mdf with laminate.
    Solid surface corian sounds interesting.
    Just wondering how you handle changing bits, the hole diameter, etc...
  1. router question..depth adjustment
    Last Post: 12-09-2012, 03:19 PM
  2. Table Saw Adjustment Screws
    By jim crockett in forum General Woodworking Q&A
    Last Post: 08-06-2009, 05:08 AM
  3. Lathe Speed Adjustment not working
    By Dawson Mossman in forum Turning Tool Questions and Show & Tell
    Last Post: 07-23-2009, 04:57 PM
  4. Table saw question about adjustment
    Last Post: 02-13-2009, 02:18 AM
  5. Table saw - Lo-Tech blade adjustment
    Last Post: 02-03-2008, 10:10 PM
