Results 1 to 10 of 11
Thread: Shellac / glaze on pine
    Oct 2010
    Twin Cities, MN
    8
    I built a "hay rake" table out of dimentional lumber and old pallet material (soft pine.) (I'm working on pix to add as requested in another thread. Just haven't gotten them done yet. ,, I'm told you all like to see lots of pix.) It was a project that was intended to be just for the practice of it and to see if I could do it. Lot's of M'nT joints, wedged tennons, breadboard ends, etc. Lot's of stuff I haven't attampted before. Well it's actually turned out pretty well, and I think it's a usuable table, so it may be spared from the firepit.
    Now I'm wondering about a finish. I think I've read somewhere, sometime, about using shellac layered with glaze (gel stain) to add some depth and color to the finish. Anyone ever heard of that? tried that? I'm afraid of the splotching because it's cheap, soft pine. Any other suggestions?
    Congrats on the build. On blotch-prone woods, many use a very thin dewaxed shellac as a sealer. This helps even out the color between the soft and hard(er) parts of some woods. I use Zinsser's "Seal Coat" which is the trade name of their clear dewaxed shellac. It is a 2lb cut out of the can so I hit that 50:50 with denatured alcohol when using it as a sealer.
    As in ALL finishing scenarios, test-pieces, test-pieces, test-pieces. Take a piece of your stock and prepare the surface exactly as you have prepared the surface of your piece. Try variations of the finish you want to use. If you are diligent and record your mixtures and sequences carefully, you can predict exactly how your finish will come out.
    My sequence on your material might go something like this, assuming the test board is already prepared as the actual piece:
    - wipe on sealer
    - wait about 20 minutes
    - touch sand if required
    - add colorant (stain, dye, whatever) . . . or not
    - let dry
    - topcoat with 2lb cut shellac
    - let dry
    - glaze for effect
    - top coat with your choice (this will vary depending on the intended use).
    Have fun.
    Congrats on the build, we look forward to seeing pics
    I agree with Glenn on the seal coat, works really well with pine!
    Oct 2010
    Twin Cities, MN
    8
    Pictures
    Finally got around to taking some pix. I still haven't put on a finish yet. I haven't come up with a good plan......
    Attached Thumbnails Attached Thumbnails Hay Rake parts R.jpg   Hay Rake base 2R.jpg   Hay Rake Brdbd ends R.jpg   Hay Rake fastenedR.jpg   Hay Rake table 2R.jpg
    5,172
    Very nice. I really like the base. Gonna have to bookmark this one!
    Very Nice Scott. I like the design and I think that the finish routine that Glenn described will work well for you don't darken it to much and use a stain that will compliment that rustic look. BTW what are the dimensions of the table.
    13,443
    That's a great looking table Scott.
    Apr 2009
    Outside the beltway
    5,255
    Nice table Scott!
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    17,472
    another vote on a great design and great looks..i wouldnt darken it to much. its looks real good with aged looking top just bring the legs into match the top in color..
    Worth the wait for the pictures, wow, you have done some really nice work there
  1. DEWAXED shellac?
    Last Post: 01-25-2013, 03:05 AM
  2. shellac
    By Rex Bloem in forum Finishing School
    Last Post: 03-17-2011, 03:12 AM
  3. matching salvaged pine flooring to existing pumpkin pine floor
    By Robert Gilmore in forum Finishing School
    Last Post: 02-23-2008, 09:45 AM
  4. amber shellac on pine anyone tried this?
    By Mike Gager in forum Finishing School
    Last Post: 02-18-2008, 04:49 PM
  5. What's up with my shellac?
    By M Toupin in forum Finishing School
    Last Post: 07-28-2007, 04:21 AM
