Results 1 to 10 of 12
Thread: Removing granite back splash!
    Santa Rosa, CA
    138
    We have a full granite back splash (see pic, I hope!). SWMBO wants it GONE! We'd like to save the granite and take it out without breaking.
    It will be replaced with tile so I don't care if the sheetrock needs replacing.
    The largest piece is 17" x 64". Has anyone done this? All advise welcome!!
    13,440
    How long has it been on there? It's possible the adhesive has deteriorated and prying would pop it loose, but you'd want to pry from all possible spots that you could, had good luck with glass doing this, but not the same. I think if you could cut the drywall around it and just take the drywall with it and remove the drywall after would be less chance of breaking it. Just my .02.
    Hate to say this....but I have tried it both times, and both times they cracked. Sorry I can't help
    Dec 2008
    Santa Claus, In
    4,779
    Heat gun maybe? Big risk of fire. Might be easier just to bust them out.
    13,360
    That looks tough with the cabinets and counter so tight.
    Maybe a heat gun and one of the vibrating multi tools?
    Santa Rosa, CA
    138
    Keep those suggestions coming!
    The granite has been there 3 years. One of those bad decisions made during the pressure of a remodel.
    I have considered cutting out the drywall but access is only to one short edge and perhaps the top. There is only a 1/8" gap between granite and cabinets. I wonder if I can cut two of the possible 4 sides of drywall and pull on the granite with them cool suction cups I see on all the DIY shows. Would the DW screws pull thru?
    My other 'plan' was wedges, long wedges and some kind of long thin blade to reach behind and free the mastic. Even as I write this I have my doubts. Seems like a scene from the 'Renovation Realites' show. I might keep a video camera running just so I can make some $$ on 'America's Funniest Home Video'
    13,440
    The drywall screws should pull through if you've got a good pull on the front side. Can you get a utility blade through on the other short side? A few scores with it should you through enough drywall to get it to let loose, wont take much of a score, but would cut all the way through on the other sides where you can.
    If you go with the suction cups, I'd put a couple of old pillows on the counter, in case it comes loose easier than you think. Should be able to rent those suction cups. Shoot, might try pulling with them before cutting the drywall, never know how well something is attached until you give it a yank.
    13,360
    The oscillating multi tool things have some very thin blades that might be able to fit in the crack between the counter and the granite. I'm amazed at how well they cut...
    Santa Rosa, CA
    138
    Vibrating multi tool! Yes a excus..., er, reason for a new tool!
    The drywall was installed with lots of screws so it might be tough. I'm most worried about harming the existing counter top. I'll tape it at the seam and put down rosin paper (the red stuff at HD) to get some protection. I've even considered removing the upper cabinets. I installed them so the reverse won't be that bad.
    I really like Darren's 'just give it a yank'. Fits my 'no guts, no glory' attitude!
    17,472
    john.. i think yur idea of the suction cup thinggys is a good one and the cutting all edges possible is another good point but rosin papaer isnt enough to protct your counter. use card board box material.. its thicker and more cushion when the pull surpizes yu and comes NOW.. you should be prepared to brake your self when that happens..those suction cups are strong and the screws should pull threw.. its the paper that yu need to score if at all possible..
  1. A Wooden Automation of a Water Droplet Splash
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 02-17-2014, 09:13 PM
  2. Granite question
    Last Post: 11-26-2010, 09:19 PM
  3. Granite tile countertops
    By Alan Bienlein in forum Carpentry and Construction
    Last Post: 05-31-2010, 09:36 PM
  4. New Craftsman 22116 Granite Top TS ~$662
    By scott spencer in forum Hot Deals
    Last Post: 02-07-2010, 06:34 PM
  5. Question on Granite tops
    By Drew Watson in forum New Tools
    Last Post: 04-23-2009, 04:07 PM
