Results 1 to 9 of 9
Thread: Bowed ply
    Mar 2009
    Lincoln AR
    142
    Bowed ply
    I have some 1/4 inch plywood that has a slight bow in it about 1/4 inch curve or so. Is there any way to wet this and flatten it back out, I stacked heavy stuff on it and it just stays the same. I clamped it between two culls and it still had a memory and went back to where it was. i USE IT FOR CRAFT WOOD BURNINGS (pictures etc) so I can't nail it to flatten it out. Help!
    Thanks
    13,448
    You may have luck spraying it down with water and weighing it down. I had a 3/4" sheet that leaned against my wall over the winter (a couple of winters ago) and warped a good 3" - 4" . I cut the pieces for my project out and nailed it up thinking the backing would square it up...no luck still had one end wanting to raise about 1 - 1 1/2" off the ground. Ended up spraying the tops and bottoms of the warped pieces with a spray bottle of warm water several times over about 2 hours, then setting 2 sacks of concrete on each end to pull them straight. After a couple of days of drying they held straight. Worth a shot.
    What I did was to wet it down....moved it to the drive way, covered the plw with a heavy blanket...and rolled the Van over top of it....was almost straight by the morning....good luck
    13,448
    Quote Originally Posted by Dom DiCara View Post
    Was it the heat from the burn-outs that ironed them out?
    Mar 2009
    Lincoln AR
    142
    All I have is a Nissan pickup, it would probably raise it off the ground!
    13,448
    Dom, I tried your suggestion, but this might have been a bit extreme...
    Ok...I'm done now....
    Mar 2009
    Lincoln AR
    142
    Answers, answers so many answers, come ya morons theres got to be a way that makes since.
    Mar 2009
    Lincoln AR
    142
    Answers, answers so many answers, come ya morons theres got to be a way that makes since. I mean how could I possibly roll a car on it's side and get it in the right place
    30,017
    Quote Originally Posted by Bill McQueen View Post
    ...I mean how could I possibly roll a car on it's side and get it in the right place
    Verrrrrry carefully.
  1. Island, or continent? (was, bowed plywood)
    Last Post: 05-11-2011, 07:28 PM
  2. Bowed Cauls - Shop Made
    Last Post: 03-16-2011, 12:24 PM
