Results 1 to 10 of 13
Thread: Shop winterization
    Chris Hatfield is offline Former Member (by the member's request)
    Aug 2010
    380
    Shop winterization
    The first freeze is going to happen tonight, and I have a bunch of stuff in the shop I didn't have the last go-round.
    Last winter, I just had a set of battery operated tools. The batteries came inside, but the tools stayed out and held up fine. Since then though, I've made several big tool purchases. I know that I'll be bringing in any finishes and glues, but what else should I be doing to protect my investments? We don't have what most would call a predictable winter, so I couldn't tell you if it's going to be dry or wet.
    The shop has a little bit of insulation. But the floor is exposed to air over the ground, it has a crappy little window that I've left cracked up until now, and the doors don't close that well - that needs to be a project I take on soon though. No heat, no power.
    Thoughts?
    North West Indiana
    6,099
    GA means Georgia right? Ya'll have winters down there???
    Jon
    Aug 2010
    380
    Occasionally. Last year was the coldest in memory. Shouldn't be that cold this year, though.
    The shop does stay cooler in the summer, and I think a touch warmer in the winter, but it takes much longer to warm up during the day.
    North West Indiana
    6,099
    When I was in the garage, I used an old woodstove to try to get enough heat to be comfortable to work without gloves on. Just "buttoning up" the shop and reducing drafts will go a long way towards personal comfort, security from critters and moisture blowing in. See the shop heat poll going on currently to get main ideas.
    Jon
    Dec 2008
    Santa Claus, In
    4,779
    Yep, stopping drafts was the first thing I went after. Helps a lot. Then I went with a wood stove, as having something to burn is not a problem around here.
    5,323
    I used to keep my finishes and glues in a small cabinet, with a 60 watt light bulb in it. That little light bulb kept the 3 X 3, 16" deep cabinet nice and warm, even in below 0°F temps.
    Aug 2010
    380
    I'm not too concerned about me being warm, it's possible damage to equipment I'm worried about.
    As for the light bulb idea - no go. No permanent power in the shop.
    3,134
    Quote Originally Posted by Chris Hatfield View Post
    Sounds like you have a neander building. No phone no lights not a single luxury like Robinson Caruso your as primitive as can be. I'll bet you don't have a Mary Ann or Ginger either. Sorry I just couldn't resist. Yes take your finishes & batteries in where it's warm.
    13,462
    Sounds like project #2.
    Closing the drafts will dramatically change the environment in there.
    As far as tools, just typical maintenance (clean and wax the cast iron, etc.), but when running motors in the cold you might let it run for 5 - 10 seconds longer to get warmed up the first few times. The hot/cold/hot/cold repetition probably would wear them out quicker (if it's really cold out, like below freezing), but most are designed to be used on job sites and in those extremes.
    If you're in a freezing area, take the water based finishes inside or to a warmer location. I've left my oil based stuff in the cold, most are still usable, some need to be put through a strainer to use. It usually takes some extreme cold to really affect them, but best to keep them warm if possible.
    13,363
    Guess it's time to move the glue and finishes.... Thanks for the reminder.
  1. Shop sweet shop-UPDATE
    Last Post: 09-24-2013, 07:31 PM
  2. great day for shop today, horrible day for shop today
    Last Post: 04-07-2013, 03:51 PM
  3. Shop Renovation: Ned's Shop gets a facelift: Relocation plans
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 10-31-2012, 12:06 AM
  4. Is the shop a dangerous place for our shop pets?
    Last Post: 07-30-2012, 08:41 PM
  5. Shop - Organizing the clamps, finally! + Shop Tour
    By Rob Damon in forum Shop Tours
    Last Post: 02-09-2011, 04:16 AM
