Results 1 to 10 of 10
Thread: Can this ugly thing be saved?
    Jun 2010
    3,220
    Here's a table, sort of, that someone made for Glassman some years ago for him to read blueprints on. Forgive the mess--still not unpacked because most of our furniture is in the *other* house that's for sale.
    He has given it to me. That means he doesn't want it. So I have to decide if I want to keep it or not for the shop. There are a few problems. A) it's too high for me. The top isn't flat but angled down toward the front. So the top is about 36" high in the front and 40" high at the back. B) it's not flat on top (obviously).
    It's very sturdy and the top is fastened on there tight--not sure exactly how. The sides you can see are one solid piece of ply.
    Is there an easy way to a) cut it down and b) make it flat? If not, should I cut it apart and save the pieces? I don't see an easy way, and I'm inclined to dump it......
    Thanks and good morning!
    AKA The Rookie
    5,317
    Take the top off (look inside the cabinets to see how it's attached) and cut the sides & back to make them flat. Reinstall the top, and that's it.
    You could probably make the whole thing shorter by cutting the doors down, too. It looks, from the pix, like there's no face frame, and the door is on with piano hinge, so the cut-down shouldn't be too hard.
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Everything can be fixed Cynthia it just depends on how much time and effort that you want to put into it. By the looks of it from the pics Like Jim said have a good look at how it is assembled and how much you want to cut it down.
    5,167
    Don't know that I would make it falt. I am always looking for a writing surface. Slanted would be good. Maybe it would be harder to pile stuff there!
    I hear the "making it shorter" bit! I'd take the height off the top. Then if you truly want it flat, that is easy to do from the top.
    Nov 2007
    2,070
    Or you could just get an adjustable chair that can be rasied.
    5,317
    ...I hear the "making it shorter" bit! I'd take the height off the top. Then if you truly want it flat, that is easy to do from the top.
    Or...You could always stand on a box, Carol! G,D&R!
    5,167
    Gee, thanks, Jim.
    I do that behind the pulpit!
    NH
    4,003
    But Carol you looked so tall next to Tom N
    Stupid hurts.
    30,002
    So does everybody else.
    Oct 2009
    Dennison, MN
    512
    If its not working for you, I wouldn't waste the energy doing anything to it.
    Dumpster.
    "Do, or do not. There is no try."
    -Yoda
  1. Ugly TN oak
    Last Post: 05-20-2013, 04:03 PM
  2. ugly No. 5 rehab
    By ken werner in forum Neander Tool Questions and Show & Tell
    Last Post: 11-18-2010, 08:57 PM
  3. Ugly TS injury **NOT ME**
    Last Post: 03-01-2009, 03:36 PM
  4. ugly visitor
    Last Post: 06-07-2007, 03:23 PM
  5. ugly visitor
    Last Post: 05-16-2007, 01:36 PM
