Results 1 to 9 of 9
Thread: Baltic Birch Plywood
    12,247
    Finally after lots of searching i found a supplier of Baltic Birch plywood. Good stuff too not made in China, Russian. Da Comrade.
    I dont know how many of you can take advantage of this place but the prices were excellent and they stock loads of other flatsheet goods.
    http://www.wanderosa.com/
    In the past i have been well extorted by the big orange borg. But alas no more am i contributing to the CEO's retirement fund.
    Example Home Depot 2X4 sheet BB 17.5mm (thats the closest they have to 3/4) = $28.50 per sheet. Thats 8sq ft for $3.56 per sheet before our HST tax.
    Go to this place and i picked up 5x5 sheets which DH dont even sell
    18mm for $1.352 per sq ft. or $33.80 per sheet.
    Then got 12mm and 15mm for .945/sq ft and 1.209 per sq ft respectively.
    Also for the first time found a ply which is select sanded one side spruce 4x8 1.088 per sqft.
    So i am a happy smiling camper. This place is in Bolton Ontario about 45 minutes from me but it was worth the drive for me.
    Not sure how many here can take advantage of this or if its good pricing by comparison to what you pay in the USA.
    Sounds like a good deal Rob....hard to find that kind of ply....especially at that price.
    My only problem is that I ran the store locator through map quest......and the final result is
    Total Travel Estimate: 20 hours 54 minutes / 1266.47 miles
    This is the big problem with living down here.....very few good lumber stores down here
    Mar 2010
    Decatur, Alabama
    518
    I've read about baltic birch plywood, but I guess I'm missing something. What exactly is the difference between it and chinese birch plywood that I see in home stores or the domestic poplar core birch I get from a local cabinet supply shop? I know there are different grades, but that aside does it finish different or is it solid birch or something?
    12,247
    Jeb its day and night. The real big thing is the number of layers. Baltic birch plywood is made up of thinner and many more plies. Results in very dense plywood that has much better flatness accuracy and holds it shape a lot better. As an example there are something like 13 plies in a 3/4 thick piece of Baltic Birch. Now compare that to normal 3/4 plywood. Its probably double.
    13,438
    From what I understand, it's very warp resistant and what I've used usually has 1/3 more layers for added strength.
    13,438
    Oops Rob beat me to the description, but here's a comparison:
    Regular plywood (Not birch, but same as the borg plywood layers):
    Baltic Birch:
    Mar 2010
    Decatur, Alabama
    518
    Interesting. The import B2 from china at the local cabinet supply is 13 layer, runs around $35/sheet for 3/4". Thin veneer, but decent quality sold for case building. It's iffy on the B grade though.
    The domestic poplar core 9 layer 3/4" with thick veneer, also B? run more like $55/sheet. It's looks better than the import and there's plenty of thickness to sand the veneer if needed though.
    Darren's pic tells most of the tale. There are varous grades so simply getting BB ply is not the whole deal. This is helpful although they leave out a few greades: http://alliedveneer.com/what-is-baltic-birch.html
    Why not "made in Russia". Most articles that I have read say best is made in Russia.
    http://reviews.ebay.com/Multi-Ply-Ba...00000002787534
    This is just one of many.
    Rob wrote "Finally after lots of searching i found a supplier of Baltic Birch plywood. Good stuff too not made in China, Russian. Da Comrade."
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
  1. Baltic birch stateside??
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 11-22-2012, 03:53 PM
  2. Baltic Birch plywood quality
    Last Post: 11-18-2011, 11:45 AM
  3. Eccentric Baltic Birch Plywood Bud Vase
    By Jim Krager in forum Lathe Project Showcase
    Last Post: 08-09-2011, 09:23 PM
  4. Sketchup Baltic Birch Ply Material?
    By Doug Shepard in forum Designs, Plans and Sketches
    Last Post: 12-15-2008, 10:25 AM
  5. Baltic Birch Shortage?
    By glenn bradley in forum Off Topic Discussion
    Last Post: 07-17-2007, 11:19 AM
