Results 1 to 10 of 14
Thread: Wood storage carts
    The Heart of Dixie
    4,268
    Wood storage carts
    I currently store my wood in/on some old grocery shelving. It works pretty well. not a lot of wasted space on the shelves and it handles the load no problem! (think shelves of can goods). The draw back is space, it really takes up a lot of floor space.
ID:	4691 Click image for larger version.
    I store lumber on one side and sheet goods on the other. It works pretty well. I probably need to thin out the sheet goods, but at least I can find what I have. I have been looking at wood racks, rolling carts, over head storage, etc and just haven't really seen anything great yet.
    I was thinking of wall storage, sheet goods on the bottom with lumber over head. But that has drawbacks. Just looking for some creative ideas. Surely someone has some great idea that doesn't waste floor space and puts the lumber right at the saw.
    Custom built boats and Kits
    Michigan
    2,436
    Jeff there was a picture in a woodworking magazine a while back, where a guy made a foldaway sheet good storage bin. It hinged on the wall of the shop and folded against the wall when not in use...but had a wheel at the opposite end of the hinge that allowed it to roll out as needed.
    I can look for the issue if you are interested.
    Punta Gorda, Florida
    902
    Jeff,
    If someone can come up with that they will be considered a genius in my book. I am going to try the solid wood storage on the wall above the sheet goods like you were talking about but I see your point. You have to climb a ladder to get to the racks and move sheets of plywood to get to the sheet that you want. I have my rack up and might add the roll out sheet goods rack like Steve is talking about. At least that might solve one of the drawbacks.
    Steve,
    I would be interested in the roll out rack that you are talking about.
    Thanks!
    Allen
    Michigan
    2,436
    Quote Originally Posted by Allen Bookout View Post
    Steve,
    Thanks!
    Allen
    I know it is out in the shop archives...I'll see if I can find it.
    The Heart of Dixie
    4,268
    I had this one against the wall and found everything stacked in front of it. Never could get to the wood without fear of tripping. Or having to move some stuff. Moving it out took up more space but it I can get the wood and sort it.
    I was thinking about a rolling sheet good bin. What Steve mentioned might work? I think there is not good way to store wood without taking up a lot of space. Since I have to drive an hour to any good supplier I tend to buy more than I really need so I have a plenty.
    My rack is behind the Unisaw and DeWalt so it comes straight out of the rack to the saw, or on some sawhorses. Can't get much closer to the saw but I can wish. Location is great. Just ties up a lot of space.
    Jeff
    Michigan
    2,436
    I looked for the magazine but I couldn't find it, so I put together a very rough drawing to give an idea. Sorry if it isn't too clear.
    The "box" is made to hold sheet goods on edge, size depends on your needs. Underneath is a swivel caster wheel to allow the box of sheet goods to swivel back against the wall of your choice. While it is in the out position it makes it closer to your table saw if you are lucky.
    The back of the box is made up with pipe. Two pipe flanges are lagged to a wall stud, the pipe arrangement is curved at bottom and top and straight in the middle to allow for two hinges... lagged to the backside of the moveable box.
    I wish I could find the article that tells how the pipe flanges, pipe and hinges all were made, but I'm sure there are creative minds that can figure that out.
    If I do find the article I will post it here.
    902
    Thanks Steve! I get the idea.
    Allen
    I had some old bed rails that I had accumulated and welded them together. First I cut one in half and used that for a base with wheels welded on the bottom. To that I welded uprights about a foot apart with a rail cut in half welded that to the top which a left brace that I could lay boards on top and bottom. I made 2 more the same size and welded every thing together 4 rails at the top and bottom. On the sides I welded some angles for more shelving for more boards. Laid a peace of plywood in the center for plywood sheets to sit on. Sure wish I had a camera to take a picture of it. That would make life a lot simpler.
    DK
    902
    Quote Originally Posted by Dave Klug View Post
    DK
    I wish that you did also Dave. I would like to see it.
    La Habra Hts. CA
    399
    Jeff I have tried several different things for my sheet goods because I use a large quantity at a time for kitchen cabinets.
    I tried to make a rolling sheet good storage rack as shown here:
Name:	Shop Fixtures 005.jpg
Name:	Shop Fixtures 006.jpg
    It's to hard to roll around with 10 to 20 sheet of melamine and plywood. But it is good for cut off sheet goods, half sheets etc. I might modify it to be part double deck.
    I made this little cart with wheels for misc. pieces
Name:	Shop Fixtures 003.jpg
    It works pretty good and is mobile.
    I had a heavy duty horizontal metal rack for sheet goods but took it out because it was too hard to use.
    I finally built a vertical storage rack. It takes up less space and is easy to use. I put it in close proximity to my slider. Actually I got the idea from Shaz, it's similar to his. I haven't taken any pics yet so don't have any to post on that rack.
    For hard wood I have the Lee Valley set up which is really good. I have it close to the floor. But am thinking about moving it higher up so I have some more low wall space. if it get to high a may just take a section and put it in another place in the shop.
Name:	Shop Tour 020.jpg
    Doug
  1. Wood Storage
    By Rich Aldrich in forum Shop Tours
    Last Post: 10-17-2014, 11:17 AM
  2. Recycled Wood and Wood Storage
    By Paul Douglass in forum Jigs and Fixtures
    Last Post: 10-24-2013, 01:47 AM
  3. Display Carts
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 09-27-2011, 07:29 PM
  4. wood storage
    By Drew Watson in forum General Woodturning Q&A
    Last Post: 10-05-2010, 01:40 AM
  5. Wood storage
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 12-06-2007, 10:19 AM
