Results 1 to 10 of 13
Thread: Hand cut dovetails tutorial - full and half-blind
    Villa Park, CA
    1,407
    I'm teaching hand cut dovetails now at Woodcraft so I wrote up these tutorials on how to do regular (through) dovetails and half-blind dovetails.
    Comments, suggestions, and pointers will be very much appreciated.
    Mike
    Ancora imparo
    13,361
    Very well documented and easy to follow Mike. I think you might have made it easy enough to follow that I might even be able to do it!
    Printing out both of those and putting them in my dovetail tool box!
    Villa Park, CA
    1,407
    Thanks for the comments.
    Wait a few days to print them out until I get all the suggestions and pointers for improvement. I'm still finding things to change on my own.
    Mike
    Ancora imparo
    NH
    4,006
    Well done Mike
    The only thing that I see is "Drawers in furniture, such as a bureau, are often all different heights. If a dovetail jig is used, the jig must be set up for each drawer, and setup is a time consuming process. It's often easier and faster to do the dovetails by hand."
    I have not had to reset up my PC dove tail jig for different height drawers. Different thickness yes but never height.
    Stupid hurts.
    Central NY State
    3,374
    Excellent tutorials Mike. Very nicely done. I have one comment. When I am marking my pin board from the tail board, I have the end of the pin board sticking out above the vise such that the end is even with the side of a plane [which is laying on its side.] When I place the tail board on top to mark the pins, the plane is moved back such that the tail board bridges between the plane and the pin board. This allows me to apply much firmer pressure on the tail board, so that it stays in place more easily. Just a small suggestion that I've found improves my accuracy. Judging from your results, you accuracy is just fine.
    10,604
    Great timing
    17,475
    well done mike,, now where is the eggs from all those doves
    Great job Mike learned a few things for sure
    12,260
    All i can say Mike is where were you when i got taught those at school. Your tutorial would have been much easier than the guy who taught me. Thanks for sharing it with us.
    BTW i ended up taking a tour of all your work. I really like your idea of a tool chest. Did you get round to making those trays actually go into draws?
    Quote Originally Posted by ken werner View Post
    Real good idea Ken but i would ask why would you not have the board flat on the workbench and achieve the same result with the pin board flush to the surface of the workbench. That is if i am understanding your plane idea.
    Villa Park, CA
    1,407
    Well done Mike
    The problem I've had with different height drawers is getting the dovetails spaced properly. For best looking dovetails, the top should be a half pin and the bottom should also be a half pin. The tails are then spaced across the height of the drawer, with some number that "fits" the space well.
    To do this, I've always had to re-adjust the jig to get the proper placement of the pins and tails when the height changed, and that meant setting up the jig again.
    I would think that without changing the jig, you wouldn't get the right layout of the pins and tails for each drawer as the width changed.
    But maybe I'm missing something so please point it out if I am.
    Mike
    Ancora imparo
  1. Hand cut dovetails exercises
    By Toni Ciuraneta in forum Handtool Project Showcase
    Last Post: 12-26-2014, 01:27 AM
  2. Replies: 20
    Last Post: 08-16-2014, 03:27 AM
  3. first hand cut dovetails
    By John Daugherty in forum Handtool Project Showcase
    Last Post: 01-28-2008, 12:40 PM
  4. Inlaid dovetails - made a video tutorial, NOT photo tutorial
    By Al Navas in forum General Woodworking Q&A
    Last Post: 10-30-2007, 08:55 AM
  5. Half Blind DT Problem
    By Mike Gabbay in forum Neander Woodworking Q&A
    Last Post: 03-20-2007, 12:35 AM
