Results 1 to 10 of 13
Thread: compound stave miter jig
    Apr 2009
    murrieta ca usa
    45
    does anybody have plans for a sled to cut compound stave on a table saw?
    13,607
    Did a quick search here but didnt' see anything Tom, but found several via Google. So what are you making (besides the sled )?
    http://www.turnedwood.com/compsled.html
    To a small child, the perfect granddad is unafraid of big dogs and fierce storms but absolutely terrified of the word boo. Robert Brault
    11,874
    Do you mean like for making barrels? As in cooperage?
    Those would have tapered ends plus the angle cut on the sides. I'm guessing no plans are available.
    Once, on the Roy Underhill show he had a cooper demonstrating how to cut the staves and shape them with a draw knife.
    Roy asked how he got the right angles and such. The answer was to "just cut them until they look right."
    Apr 2009
    murrieta ca usa
    45
    thanks Darren . I saw that one but didn't like it
    I was planing on making a couple of vases
    13,427
    The latest version of ShopNotes has a pretty nice looking taper jib on page 36.
    Here's a picture of it. The magazine has a lot of details on how to build it. Might be worth picking up if you like it.
    13,427
    I realize it wont do the bevel, but you can tilt the table saw blade for that.
    I am not sure if this will be helpful or not. There are several router bits that will make the correct bevel or 6, 8 and 12 sided vesels or in my case Octagonal Hollow core Oars. One end is Octagonal and the oar transitions in to a cylinder and then in to an elipse to stiffen behind the oar blade.
    Masts and spars on sail boats are made this way sometimes. As far as holding the staves and tapering them, that is pretty simple. Just make something like the other guys have shown you.
    First run the parallel boards past the correct router bit to get what ever angle you want then put the piece on the taper board and taper the opposite side.
    Here are the pictures of my oars and jigs to make them I used epoxy to glue them together. Initially, They were 10'6" long, I have since cut them down to 9'6" for one pair and 9' for the other. Total cost to make two sets of spoon blade oars was about $30. for the wood. The octagonal bit was about $40 also.
    http://sports.webshots.com/album/366127989OQvvXQ
    Here are the Router bits pictured in another forum.
    http://forum.woodenboat.com/showthre...h-construction
    12,351
    Very interesting how you make those oars Tim.
    Here is another source for the bit and they have some great instructions
    http://www.leevalley.com/en/wood/pag...168,46174&ap=1
    SE Minnesota
    2,527
    Nice oars, Tom.
    I did a birdsmouth gaff for the sailboat I built. Very neat way to make a light, strong hollow spar. i made an Excel based calculator for determining the size of the staves based on diameter and desired wall thickness. With that method of construction you can make oval sections that transition to round as well as single and double tapers.
  1. Use the correct blade on your compound miter saw!
    By andy fineran in forum Safety Tips
    Last Post: 12-28-2015, 12:46 AM
  2. Compound Miter
    By Jack Reynolds in forum New Tools
    Last Post: 01-13-2012, 11:35 PM
  3. new makita compound miter saw
    By Dan Noren in forum New Tools
    Last Post: 10-27-2010, 12:33 AM
  4. sliding compound miter saw fences
    By Carol Reed in forum New Tools
    Last Post: 03-18-2010, 02:46 AM
  5. ZCI on a sliding compound miter saw?
    By Jim O'Dell in forum New Tools
    Last Post: 06-18-2007, 11:48 AM
