Results 1 to 9 of 9
Thread: Another Vase or HF
    Goodland, Kansas
    4,834
    Another Vase or HF
    Here is a third one that is poplar that I did a little different shape on it. I also textured around the center of it with a burned line on both sides of the texture. I did the texture to give some life to the plain wood. It has a walnut collar and foot to kinda of offset the wood. This is 10 1/2" wide and 3 1/2" tall. It has one coat of Antique oil on it and will get a few more coats.
    Attached Thumbnails Attached Thumbnails Poplar Vase 1.jpg   Poplar Vase 2.jpg   Poplar Vase 3.jpg
    Bernie W.
    Aug 2008
    Reno, Nv
    3,632
    That one has a lot going on! Good looking texture accent. I want to start doing collars and have had some different takes...how do you do them?
    Very cool, Bernie. The texturing is a nice touch. What did you use to do it?
    Goodland, Kansas
    4,834
    Thanks Jim and Vaughn.
    Jim I take a piece of wood and make it larger than the hole. I cut a small tenon on it. I leave the area around the hole slightly thicker for more surface area to glue. I slip the tenon in with glue on both surfaces and it needs to be a tight fit. Then cut the hole in the block glued in after it has dried, finish cutting it to shape, sand and finish.
    Vaughn I used the mini sorby micro spiral system. You can cut spirals or texture with it. Had to buy the cheapy as couldn't justify $200 for the big one. This is the one I got and got the texture cutter wheel also.
    http://www.packardwoodworks.com/Merc...-srby-micromod
    Bernie W.
    Los Angeles, CA
    2,668
    Bernie, Very nice texturing detail.
    Goodland, Kansas
    4,834
    Thank you Mohammad.
    Bernie W.
    Jul 2007
    Des Moines, IA
    854
    Bernie, that is a cool piece. I have done some texturing with a tool that I made like the one on Around the Woods web site. It works pretty well but I am thinking of getting one of the texturing tools too.
    3,132
    Bernie like has already been said really, like that texturing detail.
    Steve
    Goodland, Kansas
    4,834
    Thanks Wayne. I bought this just to give it a try. I really like how it turned out so probably will be using it a lot more.
    Bernie W.
  1. Bud Vase
    By Dan Mooney in forum Flatwork Project Showcase
    Last Post: 05-07-2016, 02:27 PM
  2. Vase?
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 09-18-2011, 09:37 PM
  3. Bog Yew vase
    By George Watkins in forum Lathe Project Showcase
    Last Post: 05-12-2009, 04:49 AM
  4. bud vase,
    By gary doby in forum Lathe Project Showcase
    Last Post: 08-26-2008, 03:02 AM
  5. Another Vase
    By Cody Colston in forum Lathe Project Showcase
    Last Post: 01-18-2008, 03:30 PM
