Results 1 to 9 of 9
Thread: Safety Switch ??
    10,604
    Safety Switch ??
    I'm probably the only one who is dumb enough to need one of these.
    I almost always unplug my table saw and most other tools when I'm done using them. I'm just nervous that someone will come downstairs and hit a switch and get hurt.
    Every so often I get ready to make a cut on the TS, push the on switch and realize I have the saw unplugged. I go plug it in and the saw starts up. I forget to hit the off switch because it was never on. Some day it's going to happen when something is near the blade and launch it across the room.
    It would be nice to have a switch that automatically turns to the off position or wont turn on if there is no power to it.
    Dec 2008
    Santa Claus, In
    4,779
    Doesn't Rockler or Woodcraft have something like that? It is set up for a power failure. When the power goes down it trips and won't restart until reset. You might be able to use something like that.
    30,008
    Bob, it's called a magnetic switch. A fair amount ot equipment (especially the larger, more powerful machines) come with one from the factory. They can also be used to replace a regular switch.
    http://grizzly.com/products/searchre...20switch&new=1
    Independence, Kentucky
    1,354
    Bob you will need to install a magnetic contactor to do what you are wanting. With any power interruption it will drop out and you need to push the start button to re start your machine.
    Chuck
    17,471
    two things here.. one i have a disconnect right below the saw table to hit while changing blades,, and two the switch is magnetic one that needs to be turned to turn on after it is off.. that keeps me safe.. and if i am gonna be gone and the possibility of the shop having someone else in there the disconnect is on the off position.
    10,604
    Time to call Grizzly
    Dec 2008
    Portland, Oregon
    1,898
    I found this on the Woodcraft site, if you don't want to retrofit your equipment with a new switch, this is an alternative. There is a video clip on the page that shows how it works.
    SafeStart Click Here
    Jesus was a Woodworker
    12,251
    This is a great post Bob Another big one for shop safety.
    I believe in those magnetic switches for sure.
    I have 2 of those switches. They work great
  1. TS Safety Switch
    By Ken Cook in forum Jigs and Fixtures
    Last Post: 09-29-2013, 06:45 PM
  2. Safety switch inserts
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 09-28-2011, 10:49 AM
  3. Switch Hitter vs Switch Pitcher
    Last Post: 06-17-2011, 12:53 PM
  4. Let's see your TS switch safety upgrades
    Last Post: 01-25-2009, 06:19 PM
  5. Switch hit
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 10-26-2008, 04:40 PM
