Results 1 to 8 of 8
Thread: prefered size of bandsaw blade?
    17,470
    ok for your uses, on a 14" bandsaw, what size and teeth configuration is your two main go to sizes.. and i am not looking for resawing just the normal curve cutting and general use stuff..
    5,317
    Generally, I use 3/16" 6 tooth or 1/4" 4 tooth blades on mine.
    I like 1/8" blades, but they only seem to come in 14 tooth, and I'd prefer something more like an 8 tooth one.
    A 3/16" blade will still cut thru a reasonably tight radius, though.
    Palm Springs, Ca
    1,166
    You can contact Louis Ittura - websearch - he is a bandsaw expert back east somewhere - he helped me with mine and prices are good and ships out fast
    11,825
    3/8"X6 tpi is my 90% do almost everything blade.
    For tight curves the 1/8" or 1/4" are great.
    For milling I (currently) use a 3/4"X3 tpi blade but would prefer a 4 tpi.
    When my 12" riser is installed I'll use no more than a 1/2"X4 tpi for milling because of possible tensioning issues.
    30,002
    I use a 1/2" x 3 tpi for 99% of my cuts, but most of my bandsaw's job is cutting turning blanks, and I'm willing to sacrifice turning radius for blade strength. I do have a 1/4" x 6 tpi and (I think) an 1/8" x 6 or 8 tpi for when I do want to cut cleaner, tighter curves. For the little bit of resawing I do, I use a 1/2" Woodslicer.
    ...When my 12" riser is installed I'll use no more than a 1/2"X4 tpi for milling because of possible tensioning issues.
    What tensioning issues? I'm pretty certain a 3/4" blade needs the same tension regardless of its length. A longer blade may require a longer distance traveled by the tension adjustment mechanism, the the actual pounds of tension will ultimately be the same. If you're satisfied with the results from a 3/4" blade now, you most likely will still be happy with the same width on the taller saw.
    That said, I've never been real happy running a 3/4" blade on mine. I bought the 3/4" blade that Suffolk Woodworking recommended for resawing, but it didn't hold a candle to the 1/2" Woodslicer.
    11,825
    Vaughn, there was a thread a while back on this issue. I had never considered there might be an issue.
    But, it seems, the extra length of the riser allows so much flex you cannot fully tension a 3/4" blade.
    I'll do a search for the thread at another time.
    30,002
    I seem to recall seeing the thread, but I think the riser block flexing is a red herring. I can see the potential for the tensioning spring to not be stiff enough to properly tension a 3/4" blade, but not the riser block. My opinion, of course.
    I have the riser block on a 14" Grizzly. Tensioned a 3/4 blade with no problem at all. Took a 10 inch log down to 1" planking with no problem. Everyday use is still a 3/8 though
  1. blade size and cutting rpm
    By keith Boutselis in forum General Woodworking Q&A
    Last Post: 03-05-2012, 05:33 PM
  2. Bandsaw Blade
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 01-09-2010, 01:26 AM
  3. What size band saw blade do you suggest?
    Last Post: 11-24-2009, 05:15 AM
  4. Mini Max bandsaw levelling bolt thread size
    By Jim O'Dell in forum New Tools
    Last Post: 06-29-2007, 02:16 AM
  5. What bandsaw blade?
    By George Conklin in forum General Woodturning Q&A
    Last Post: 11-26-2006, 01:07 AM
Tags for this Thread
