Results 1 to 10 of 13
Thread: Wood Balls or Spheres
    Jun 2010
    3,220
    I saw these somewhere....like this photo....and I thought they were beautiful. How do you turn wood spheres?
    thanks all
    AKA The Rookie
    Quote Originally Posted by Cynthia White View Post
    thanks all
    On a Lathe....
    Jun 2010
    3,220
    Thanks Don, you're always such a treasure trove of information. If figured they were turned on lathe which is why I posted it in the Woodturning Forum.
    AKA The Rookie
    17,470
    yu take and cut them out on the Tsaw first to approx size then keep taking alittle of each flat till it tries to roll away from yu then yu put ti on the sander and sand alittel of each flat with a curved sweep then yu take to the lathe to true it up and fill in the holes that held it on the lathe.
    Aug 2008
    Reno, Nv
    3,632
    Hutch had a post about those last year? Get a block about the size your going to make and glue a waste block on each side. Turn as round as possible leaving the block sides a bit high. Part off the blocks and make to friction chucks, pop in your shelf padding for traction on opposing sides of the high spots...finish rounding! Some guys do them in half's and glue them back together and will add a filler, stone, inlace...what have you, to hide the joint. Hope that helps.
    So when are you getting your lathe so you can use all this info Cynthia
    30,008
    There are several ways to do it.
    Here's one I found on YouTube, but there are others there, too...
    http://www.youtube.com/watch?v=rqi5y...eature=related
    17,470
    hey vaughn that guy was using a bowl lathe right? and if so can one of those extend enough to make spindles say 36" long as well?
    Tellico Plains, Tennessee
    4,351
    thanks all
    Vaughn's video was very interesting... I haven't found it yet, but also saw one where they guy use pvc pipe to make chucks to hold the ball so he could turn both ends and not have to cut the nubs off and resand... can also use the same pvc chucks to turn eggs.
    Chuck
    Tellico Plains, TN
    30,008
    Yep, the VB-36 is among the best bowl lathes out there. As far as I know though, the "long bed" version can only handle spindles up to 31" long. Most guys who can afford a VB-36 (about $8000 for the short bed model) have enough spare change to buy a conventional lathe for longer spindles.
    17,470
    thanks vaughn looks like i will be gettin any round stuff down elsewhere
  1. Moink Balls!
    By Brent Dowell in forum The Cook Shack
    Last Post: 02-24-2014, 04:38 AM
  2. Chicken Soup with Matzoh Balls Recipe
    Last Post: 02-01-2011, 07:56 PM
  3. Hair balls
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 05-31-2010, 05:14 AM
  4. How much can I expect to pay for the turning of some MDF spheres?
    By Joseph Shaul in forum General Woodturning Q&A
    Last Post: 03-17-2010, 09:15 PM
  5. Root balls?
    By Al killian in forum General Woodturning Q&A
    Last Post: 11-30-2007, 07:05 PM
