Results 1 to 10 of 17
Thread: gilding project
    Apr 2009
    Outside the beltway
    5,261
    gilding project
    From stripping to prepping and sanding, sealing and coating with flat black to adding the red under coats [4] to applying the 23K gold leaf. I am tired of this table ! The mirror was a snap. Gilded over carved soap stone. But we had to strip the medal frame and soap stone. I painted the frame flat black also and applyed the red undercoat [4] times and gilded.
    Attached Thumbnails Attached Thumbnails IMAGE_080.jpg   IMAGE_099.jpg   IMAGE_098.jpg   IMAGE_091.jpg   IMAGE_092.jpg
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Central NY State
    3,374
    Looks like some very painstaking work there. Do you get tense doing it, or is it a walk in the park for you by now?
    Apr 2009
    Outside the beltway
    5,261
    It is a mind drainer. You need still air , no interruptions and a good amount of time, 6 hours at the minimum for each sit when applying the gold. I like the work , the quite and the satisfaction of the Big Smile when I deliver the work.
    The problem with this job was the portion around the skirt of the table was all a paper applica which had to have malleable sealer coats.
    17,475
    well done dave,,it sure made that piece snap
    thanks for showing us the final out come
    Los Angeles, CA
    2,668
    Nice job Dave.
    10,604
    Wow, looks like something you would find in a museum.
    Beautiful work Dave.
    Honolulu, Hawaii
    1,103
    gilding project
    Nice work Dave. Reminds me of the gilding I used to do on fire apparatus.
    May I ask, why the red primer? What color sizing did you use, or clear?
    Very nice burnish. I have a frame to do, someday but not nearly as elaborate as that one.
    Real nice job. Thanks for the pix.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Apr 2009
    Outside the beltway
    5,261
    More pic's and detail information on gilding process
    Toni the red clay is called the Bowl or base coats. Red gives a brighter warmer look to the gold where as the ocher color tone adds a cooler look.
    One of the processes I use is double gilding for ornate work. The 1st pic is loading the knife with a sheet of gold I pick it up in the middle of the sheet Pic 5 shows laying the sheet down and pic 6 is a line I placed on the material to be gilded.
    Pic 2 shows the difference between a single sheet vs. double loading or double leaf gilding. Pic 3 is a small section of single leaf gilding and Pic 4 is a section of double leaf gilding.
    By double leafing time is saved from having do cut more gold and lay over the 1st piece. This always the gilt to get into the recesses. Is also allows the tamping brush to remain free from picking up and sizing [glue / varnish] from getting on the tamping brush which would cause the gold to stick to the brush and create other problems.
    Pick 7, tamping down the gold. At this point the gold is adhering to the sizing which is just about dry and at a point called tack. During the time of tamping the brush also becomes a mop and catches what is call the flacks and then the squeing is done which deposits the small flacks into the crevasses of the moldings. With the 1 sheet process this can not be done and thus you can not get 98% coverage.
    Attached Thumbnails Attached Thumbnails IMAGE_106.jpg   IMAGE_105.jpg   IMAGE_104.jpg   IMAGE_103.jpg   IMAGE_100.jpg
    Amazing work, Dave.
    Dec 2008
    Santa Claus, In
    4,779
    Great work Dave.
  1. doing some more gilding
    Last Post: 01-21-2014, 08:49 PM
  2. gilding
    Last Post: 01-09-2014, 12:07 AM
  3. Jarrod is Gilding
    Last Post: 07-14-2011, 11:51 AM
  4. Gilding project not on wood
    Last Post: 11-25-2010, 03:28 PM
  5. another gilding projest I did
    Last Post: 11-25-2010, 01:25 AM
