Results 1 to 10 of 12
Thread: SU Star Challenge
    SE Minnesota
    2,526
    SU Star Challenge
    I don't know if anyone is interested but here we go.
    Here's a star I drew this morning in SketchUp. It is 3D and the back looks the same as the front. Who knows? Maybe this is the back. Anyway the skins are stretched over lines and nothing is flat.
    13,442
    No luck so far...will try again tonight.
    SE Minnesota
    2,526
    Maybe I'll have to make more views of it.
    I tried Dave....no luck
    13,442
    I think I got close...
    I know...edge points are on again and too many points on the star....
    13,442
    Attempt #2
    SE Minnesota
    2,526
    Not bad although it's inside out. Will you share how you did it?
    13,442
    Inside out?
    1. I drew a circle, and divided it into 5 parts.
    2. I then drew lines from the edges of the 5 parts to the center of the circle.
    3. Next drew arcs between the outer endpoints on the circle and removed the outward curves of the circle
    4. Using the move tool and holding Alt I pulled out the center endpoint from the circle.
    5. Made my object a component and copied it.
    6. I inverted the copy using scale to -1 and pieced the two together.
    Probably not even close to what you did, but it's what I came up with.
    SE Minnesota
    2,526
    That's pretty good. Not quite what I did and the result is a bit different but I like how you approached it. I mentioned that I need to make views from other points of view. One thing you can't see in mine is that the surface is rounded over in the area between the points. I'll let you stew on that and as soon as I get a few minutes, I'll show how I did it.
    SE Minnesota
    2,526
    Darren and Dom, I hope this will help.
  1. My First Finial Star
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 09-26-2011, 01:35 AM
  2. My Second Finial Star
    Last Post: 09-26-2011, 01:31 AM
  3. Star Spangled Banner
    Last Post: 09-05-2011, 03:09 PM
  4. Happy Star Wars Day!
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 05-04-2011, 05:24 PM
  5. Terrco K-Star Dupli Carver
    By Karl Franz in forum Old Ads
    Last Post: 10-15-2009, 10:02 PM
