Results 1 to 10 of 21
Thread: math help
    Dec 2008
    Santa Claus, In
    4,779
    math help
    I need to build a octagon, outside diameter of 12 inch. I know the cut will be 22.5 but what is the length? I know how to do this, but for the life of me I am drawing a blank this morning.
    I am getting 4.97 inch, guess I should throw that out as well. Sound right?
    Apr 2009
    Outside the beltway
    5,255
    daaaaaaa I draw a blank
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Dec 2008
    falcon heights, minnesota
    5,610
    draw a circle 12" in diameter, divide it by 8, and connect where the circle and lines intersect. that way, your outer points are at the 12" diameter mark.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    5,610
    just ran it through sketchup, and i get 4 7/16".
    Dec 2008
    Santa Claus, In
    4,779
    Thanks Dan, probably right on the money. One more thing to add to my to do list.
    13,448
    I'm drawing a blank too, but I want to say you're looking for the hypotenuse of an acute triange (one which all angles are less than 90 degrees). Haven't found a good example of the forumla or a calculator. All calculators I've found for hypotenuse are based on one side being 90 degrees.
    Dec 2008
    Santa Claus, In
    4,779
    Well then we will call this the turkey day challenge
    SU is your friend:
    No lets see it been 40 years since I had to do this but as I recall This is a SAS problem. Side Angle Side. You take the length of the two side squared and add them together multiply the by the sine of the included angle and take the square root of the result.
    Oh and the reason the pythagorean theorem works as A^2=B^2+C^2 is because the sine of 90 degrees is 1.
  1. Common Core Math.
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 02-10-2016, 05:05 PM
  2. Math Algebra Guru
    Last Post: 01-18-2011, 04:02 AM
  3. 8 sided pyramid math problem
    By Brian Corrigan in forum Designs, Plans and Sketches
    Last Post: 12-16-2010, 06:17 AM
  4. math question
    Last Post: 11-24-2008, 12:31 PM
  5. Math Skills
    Last Post: 05-03-2008, 10:31 PM
