Results 1 to 5 of 5
Thread: Setting Laser for thickness
    Palm Springs, Ca
    1,169
    I am refering a friend to read this website and post that emailed me about how to set the laser on the hollowing rig so you do not cut thru into the wall of it. I thought others may have a better way or different way than mine so please post if you do.
    To make it simple I guess....... I set mine about 1/4" away from the cutting tip or edge of the cutter depending on how im using it. If I start to cut on the side of the cutter going down into the vessel I reset the laser to the side keeping the same distance from it. This works well for me to keep the same thickness but ill defer to others as they may have a better way to do it..........................
    Goodland, Kansas
    4,834
    I have a little 3 X 5 card measured out in 1/8" increments. I do the same as you do using the card to set the thickness I want and change it when I change the cutting place in the HF.
    Bernie W.
    Nov 2010
    Richmond, MI near Port Huron
    64
    Hi There So I understand... you set the laser dot to the side of the cutter When the dot drops off of the piece you have your wall thicknes.??
    Palm Springs, Ca
    1,169
    yep.......that is bascially it..........but you have to adjust it alot so you do not go thru the wall of the vessel
    Aug 2008
    Reno, Nv
    3,632
    And you need to re-orientate the laser when working with different tools and sometimes, just due to vibration.
  1. Need advice on a thickness planer
    By Ninh Shepherd in forum New Tools
    Last Post: 01-30-2014, 02:58 PM
  2. Vacuum bag material thickness?
    By Tony Baideme in forum General Woodworking Q&A
    Last Post: 01-12-2014, 07:10 PM
  3. Panel Thickness on Cab Doors
    By gary curtis in forum General Woodworking Q&A
    Last Post: 09-11-2007, 09:29 PM
  4. Wood Thickness
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 06-28-2007, 11:42 PM
  5. Thickness sander vs. planer?
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 11-03-2006, 08:15 PM
