Results 1 to 10 of 12
Thread: Dyeing Wood
    Jun 2010
    3,220
    Dyeing Wood
    Good Morning!
    If one wants to dye (or stain--I'm not sure the difference) wood a bright color like blue or green, what do you use, and where do you get it?
    cynthia
    AKA The Rookie
    Quote Originally Posted by Cynthia White View Post
    Good Morning!
    cynthia
    Transtint, woodcraft
    "Thereís a lot of work being done today that doesnít have any soul in it. The technique may be the utmost perfection, yet it is lifeless. It doesnít have a soul. I hope my furniture has a soul to it." - Sam Maloof
    Oliver Springs, TN
    1,726
    TransTint is my go to dye. I mix it with alcohol. I get it at woodcraft, but if I had to order I'd get it from here http://www.homesteadfinishingproduct.../TransTint.htm
    Bellingham
    2,450
    Apparently food coloring will work per this article.
    http://www.woodworking.org/WC/Garchi...colorants.html
    It is not sun proof but according to the article should last for a few years. The part on food coloring is down under the section titled "Adding Colorants: Common household colorants"
    5,323
    Quote Originally Posted by John Daugherty View Post
    Mine, too. BTW, Homestead is MUCH cheaper - particularly if you buy more than one bottle (mix & match). I paid nearly $20 for a bottle at Woodcraft, and Homestead had it for around $15.
    17,477
    try RIT dye cynthia, the turners have been using it, and it appears vibrant..a guy made a real nice guitar here and used rit dye for the green and its was outstanding..
    872
    Good Morning!
    If one wants to dye or stain
    Here's what I use.
    https://www.woodessence.com/ColorFX-...ts-P51C12.aspx
    plus I ordered Orange as an extra. It is a dye that mixes with either water or what I use; Isopropyl Alcohol 99% pure to get faster drying for my pens as well as no grain raising. I generally would mix about 1 - 2 tsps of Isopropyl with 4 - 5 drops of the dye for a very deep colour.
    Lots of choices, this is the only one I've tried.
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    Long Hill Township, NJ
    467
    Cynthia:
    Timing is everything. I used Levenger's Amethyst Fountain Pen ink over maple to make a handle for a magnifying glass.
    I was 99.44% done with the post, and cancelled out of the preview post I was too angry to re-enter the post.
    Anyway - the picture is below.
    The color is a fairly dark purple and with some Behlen's Woodturning finish covered by some rattle can poly it came out well.
    I've used some Transtint dye to dye a pen red. The mistake I made was to attempt to tint the finish instead of the wood. I tinted some Behlen's aand applied it. I had trouble getting even coverage. Subsequent applications of the wipe on finish would "meld" with the prior layer and remove the tinted layer.
    For the purple I sanded and then applied directly to the wood and finished over it. The first coat of finish removed a little of the ink/dye but not much.
    Good luck and experiment on little projects.
    Cheers
    Jim
    Jan 2010
    Victoria BC
    87
    Apr 2009
    Outside the beltway
    5,262
    Quote Originally Posted by Brian McMillan View Post
    These are the best dyes. I also use water born powder dyes.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
  1. dyeing pen blanks, need your help UPDATE
    By Bob Gibson in forum General Woodturning Q&A
    Last Post: 01-19-2012, 11:17 AM
  2. Replies: 12
    Last Post: 02-08-2011, 11:36 PM
  3. New wood stash and drying wood
    By Dave Black in forum Shop Tours
    Last Post: 09-24-2010, 05:43 PM
  4. Wood glorious wood .....( from the movie of Oliver Twist)
    Last Post: 11-09-2009, 10:30 PM
  5. wood screen door build - which wood should i use?
    By Mike Gager in forum Carpentry and Construction
    Last Post: 03-07-2009, 02:24 AM
