These crickets are loud.
I decided to try and get little things taken care of around the shop so that when it's time for the big stuff, I wouldn't have so much to trip on.
Stuff done in the last two weekends:
-Chisel rack made and up on wall. Also holds my one mallet.
-Hammer holder made and up on wall. It's horrible, but also holds my Japanese saw.
-Misc cabinet made from my former drill press table carcass. Holds my wax, OEM parts for the bandsaw, a bit of safety gear.
-Circular saw rack. Needs to be redone, but it's out of the way for now.
-Put my 1000w work light up on the wall as well.
Not quite yet ready to start putting up new walls, but it's close. A bit more cleanup work, and deconstruction of my UTS is in order next, along with figuring out what to do with all the bins I still have.
As I've stated previously,
this is what I'm planning for one side of the shop, and something similar on the other side for my planer. What I'm trying to decide now is if I go with drawers for at least one of them, which I am planning on doing, is how big to make them. It's important, because it will dictate how I construct the unit. I'm unsure if a vertical support in the middle will be necessary. I won't have room for a full, heavy duty bench in the shop if I make two, so I'm trying to decide if I overbuild one and make it bench-like, or sacrifice one and have an actual cabinet bench - a bench that would have to also double as a lunchbox planer table. I've also not ruled out putting the planer
back on a flip-top cart and storing it under the miter saw. Or a couple other options, so long as I didn't have to keep it on the floor and lift it up to wherever I will use it. A low cart might work as well, but I don't know how uncomfortable that would be.
Obviously, on a budget, more drawers = more money. For making the drawers themselves, and the slides. Building them with a couple drawers and the rest shelves would work as well. I could also size the shelves to about the size I want the drawers and add them as finances allow. So again, I'm back to how many drawers/slots I want in each one.
