Results 1 to 10 of 11
Thread: Best way to cut a counter top
    Apr 2008
    I am in Holland Michigan.
    16
    I have to install a new counter top on a cupboard, and I am trying to find out the best way to cut it? Thank You for the Helping Hand!
    Saved, and so gratefull, Consider who created it ALL
    A Howard, it would help if we knew what the counter top was made of....
    Apr 2008
    16
    Sorry, The top is made up with osb board, or particle board is it. It is laminated with the plastic laminate that comes on most premanufactured units.
    NH
    4,005
    I would flip it over and cut it from the back with a circular saw.
    Stupid hurts.
    I'll add that a high tooth count blade will give you a cleaner cut.
    BTDT...
    10,604
    Putting masking tape on the cut first is supposed to help keep the laminate from chipping when cutting.
    NH
    4,005
    That's for when you have no other choice but to cut it from the top. And the taps is to keep the saw from scratching the top more than keeping it from chipping.If you cut from the top it is best to cut it with a jig saw with down stroke teeth.
    Stupid hurts.
    10,604
    Thanks for the tip Chuck
    The flip it over is easier said than done as pre made counters have lumps an such, and simple measurements are confusing. Lay out the top placement by placing the sink upside down withe the top in place. I use Blue tape to locate the top around the perimiter, then measure inand layout the hole so that you allow the proper lip. (some sinks come with a pattern) Add more tape and use a box knife and scoure a line in the laminate. then drill a hole near a corner (rememberb the corners should be round else the corners protrude beyond the lip DAMHIK) Using a good sabre saw with a finer tooth blade cut along the scored line (the scoring will help prevent chipping) support the "plug" as you get to the halfway and beyond point.
    Not too difficult if you take your time and do it right, rather than fast and easy, fast and easy is for when someone else is paying for your mistakes.
  1. counter top kiln
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 04-05-2013, 12:23 AM
  2. Counter top Finish
    By Gary Rutledge in forum Finishing School
    Last Post: 01-13-2012, 05:10 AM
  3. Concrete Counter Top
    Last Post: 08-31-2010, 01:19 PM
  4. Counter Top Alignment
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 08-12-2010, 04:57 PM
  5. Has anyone used quartz for a counter top?........
    By Mark Rios in forum Carpentry and Construction
    Last Post: 12-04-2006, 01:22 AM
