Results 1 to 10 of 17
Thread: Plate Rack Insert
    13,448
    Plate Rack Insert
    As mentioned on my house updates thread, I planned to build a plate rack insert to go where the old microwave used to be. The cabinet itself was made about 6" shallower by removing it, cutting 6" off the back, and then putting bead board on to match the rest of the kitchen.
    Tonight I was cutting out shelving for the other cabinets and decided to try and knock out the case for the rack. Here is the dry fit. There will be two drawers in the openings below, need to add the rails for them yet.
    The layout for the holes that will support the 3/8" dowels, spaced 2 1/4" apart and 7" between the rows.
    The top and bottom attached for drilling on the drill press. I set the depth of the bit to stop about 1/2" into the bottom board.
    The top and bottom holes drilled and matched up.
    Will assemble it this weekend...stay tuned.
    Oh, I do plan to add a stop on the front to keep the plates from rolling out, LOML is buying new plates, so waiting to see what she gets and add accordingly. However the current ones are square, so no lip needed.
    Attached Thumbnails Attached Thumbnails IMG_20101202_215529.jpg   IMG_20101202_215333.jpg   IMG_20101202_222911.jpg   IMG_20101202_222951.jpg
    17,472
    just love the smellof some real flat work early in the am go darren go
    10,604
    Looking good
    Sep 2007
    Plainwell, Michigan
    4,857
    I came THAT close to putting a plate rack in, wish now I had anxious to see the final results
    13,448
    Thanks guys. Probably would have gotten it done and ready for paint, but still shuffling stuff around and working out of boxes on the floor of the shop, need to get some cabinets and work tables built. Maybe in a few weeks...next couple of weekends are pretty packed out with holiday events.
    13,448
    Did fit in some shop time today to assemble the plate rack.
    After getting it in place my wife has made the executive decision that the bottom section will become a wine rack instead, so it will be getting some modifications to add some pigeon hole to it instead of drawers, but here it is during the test fit.
    Attached Thumbnails Attached Thumbnails IMG_20101205_174746.jpg   IMG_20101205_175150.jpg   IMG_20101205_175952.jpg
    10,604
    The wine rack is a good idea
    Sep 2007
    Plainwell, Michigan
    4,857
    I also like the idea of the wine rack :0 one question, will you be putting in a strip of wood or something to stop the plates from rolling out the front?
    17,472
    Quote Originally Posted by Tom Niemi View Post
    no he will just put a bungy cord across the frnt tom.. the hooks were on back order so they arent in there yet
    13,448
  1. Grizzly TS Insert
    By Darren Wright in forum Computer-Aided Equipment Project Showcase
    Last Post: 11-09-2015, 04:09 PM
  2. Zero Clearance insert
    By Rob Keeble in forum Jigs and Fixtures
    Last Post: 09-28-2015, 03:26 PM
  3. Zero clearance insert
    By Ken Cook in forum Jigs and Fixtures
    Last Post: 09-07-2013, 05:24 PM
  4. chuck plate/face plate
    Last Post: 10-27-2009, 05:17 PM
  5. table saw insert
    By edward alexander in forum Jigs and Fixtures
    Last Post: 05-11-2009, 01:18 PM
Tags for this Thread
