Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 64
Thread: Subfloor Divot Repair?
    13,360
    Question Subfloor Divot Repair?
    So, ripping up a little more parquet flooring before we get some carpet installed on Tuesday.
    Well, the parquet in the kitchen came up pretty good, until I got to a place where the previous owners had nailed down the 1/2" particle board underlayment with ring shank nails. I thought that was hard to rip up.
    I'm doing a small section today by the front door and hallway, and apparently, they not only used ring shanks to hold the underlayment down, but they splurged on some construction adhesive as well...
    So, everynow and then when I pull up some of the underlayment, some of the subfloor comes up as well leaving some ragged long divots.
    Do I need to fill these somehow before the carpet gets layed? What should I use?
    Thanks!
    Dec 2008
    Santa Claus, In
    4,779
    I would say a lot depends on the pad you are going to use. With a high grade pad and shallow divots, shouldn't be a problem.
    I would use Durhams Rock Hard Water Putty to fill any deep ones. http://www.waterputty.com/
    13,360
    Sharon read online to use the water putty, or modified thinset for shallow ones. Looks like I'm going to run to town and get some, cause at the rate I'm going, it'll be quite a while before I get this little section up...
    And I'll need to make sure I get the divots repaired tonight so they have time to setup...
    17,472
    brent dura bond 90 will work as well,, its what alot of drywallers use for the first coat, its hard doesnt shrimk and sets up fast 90 stands for the time frame for hardness mix with warm water and it willgo alitle faster,
    Apr 2010
    North of Reno, NV...middle of the desert
    1,930
    He already left for the store but I called him. He's going to check it out to.
    Thanks Larry and Steve (this day has long written all over it )
    Dec 2008
    Santa Claus, In
    4,779
    You will be fine, long days are what makes a good relationship. Now go get your hammer and pry bar and help Brent
    5,320
    Definitely fill the divots! In a previous house, we had a couple missing linoleum tiles (on a slab) and thought we could just install carpet and thick padding over them. WRONG! After a few months, you could see the print of every missing piece of tile, and we had to take up the carpet, fill in the missing tiles, and re-lay the carpet. Definitely a posterior pain generator!
    Apr 2010
    1,930
    I was doing the shaving with the "Multi Functional Power Tool". Following up behind Brent breaking out the big pieces. He took over when he got finished and I continued with nail pulling. I think this is what they call "team work".
    Good thing the carpet doesn't get delivered till Tuesday. I think we need the extra day to make sure everything is ready
    fill the divots....remember carpet gets stretched and you will have what boils down to a crater if you dont
    +1 on the durabond
    13,360
    Thanks for all the advice guys. Just doesn't seem right to get expensive new carpet and not do the proper prep work.
    It's not that I hate parquet in and of itself, it's just that the stuff that is/was on every floor here was so poorly laid. The corners didn't match up, there were gaps growing between the tiles in places. Just ugly.
    I'm very lucky the kitchen stuff wasn't laid down like this little stretch or I would have lost my mind. I was literally prying it up almost tile by tile. Every now and then I'd get lucky and get 4 or 6, but not very often.
    The had large quantities of the goop all around the edges and during the removal I managed to remove the top layer of the ply in quite a few places.
    Don't know what I would have done without the oscillating multi tool. It really saved the day in cutting/melting the construction adhesive so I could get the stuck on pieces of particle board up. Sure I was on the floor for a couple of hours with it and I can barely feel my hands, but it did a great job...
    Here are a few pics.
    When I got back from the borg with the patching stuff, There she was going to town!
    She caught a pic of me using the multi tool
    An example of the particle board underlayment stuck to the floor. Using the blade on the multi tool it made it not too bad to cut the glue and peel the pieces off.
    examples of where the ply was ripped...
    Some floor leveler compund. There was a bunch of similar products, fixitall, rock hard water putty, this, and something else. This actually said 'floor leverl', so I bought it. And it had the number 90 on it, like the product Larry suggested...
  1. Chair repair con't.
    By Gary Rubendall in forum Flatwork Project Showcase
    Last Post: 06-03-2014, 01:21 AM
  2. Repair Project
    Last Post: 06-06-2012, 01:38 PM
  3. Canon repair
    Last Post: 03-22-2012, 10:21 PM
  4. blade repair
    By ken lutes in forum General Woodworking Q&A
    Last Post: 03-14-2010, 02:09 PM
  5. Repair Job
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 06-11-2007, 12:52 AM
