Results 1 to 3 of 3
Thread: wood movement chart info
    17,470
    this wknd i ran into a spot where i wasnt sure what to do, so sent out some pm's got some replys but later than i needed them,, which was fine i was just in a hurry to do this part and so i done some more looking on the net and found a good article that can help others like me next time.. i had a panel of walnut that was going to be trapped between two rails and i didnt want it to spread the piece apart with the movement in temps threw out its life time.. so found this article and am inserting a link to where it can be found. you need to sign up for the site if you arent but its definitely worth it to be a member of this site..
    http://www.finewoodworking.com/Skill....aspx?id=27129
    the panel i had was 15.5 wide, and the area you are in affects the amount of movement yu can expect , but this guy does work for the whole country and so he uses the worst case scenario and so did i on this.. so after yu have read this give me your answers for the amount of movement i should allow for on this walnut panel that way i can see if iread it right and yu can have a better understand ing of movement after reading this article
    13,353
    Flatsawn or Quartersawn?
    I'll assume the worst.
    (15.5 * .0027 * 10) = .4185 ~= 13/32
    So I guess the panel width should be 15 3/32?
    That seems like a surprising large amount of movement to me...
    I must have done something wrong...
    17,470
    its flat sawn and that was what i thought as well brent.. went with 3/8"
  1. wood movement
    By Roger Pozzi in forum General Woodworking Q&A
    Last Post: 12-13-2014, 04:16 PM
  2. Wood Movement
    By Chas Jones in forum General Woodturning Q&A
    Last Post: 01-30-2012, 08:32 PM
  3. Wood Movement
    Last Post: 12-27-2010, 04:02 PM
  4. how common is wood movement really?
    Last Post: 02-13-2008, 03:01 PM
  5. wood movement
    By Gene Miller in forum General Woodworking Q&A
    Last Post: 09-24-2007, 11:01 PM
Tags for this Thread
