View Poll Results: panels in projects, your method
Voters
35. You may not vote on this poll
  • pre-finish panels
    26 74.29%
  • no i dont pre-finish panels
    8 22.86%
  • leave panels loose in project
    21 60.00%
  • anchor panels in project
    5 14.29%
Multiple Choice Poll.
Results 1 to 10 of 29
Thread: pre finish or not
    17,472
    pre finish or not
    you have a project with panels in it, do you prefinish it or just finish together?
    do you glue in panels or leave them loose?
    Constantine, MI
    7,890
    So far I have had good luck just applying the sealer coat (I use dewaxed shellac) prior to assembly. I apply the finish coats after assembly. I also place a drop of glue at the center of the top and bottom rails to hold the panel centered.
    This works for me, but please remember I live in a high desert climate and the humidity variations here are much less than in many other parts of the world.
    www.wrworkshop.com
    Dec 2008
    Santa Claus, In
    4,779
    Prefinish and one drop of glue in the middle.
    4,552
    I use a headless pin in the center
    A Turn N Time
    Frog Pond Guitars
    10,604
    Well I guess my answers were wrong
    Apr 2009
    Outside the beltway
    5,255
    Larry you should always pre finish everything you can before assembling. Keep any over spray off. Or if you are brushing it is much easier to lay out flat work then over head or sides.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    If I'm staining my project I'll Sand and stain the panels and the profiled edge of the stiles and rails. When I assemble them I'll use a pin nailer and put a pin in the top and bottom of the center of the panel.
    I pre-finish panels and any hard to get to areas. I sometimes pre-finish so much the shop looks like a Ready To Assemble furniture staging area. I fix panels in place with space balls or like substance or for smaller pieces I just tack one or two areas with glue.
    Dec 2010
    Southern Oregon
    10
    I agree with prefinishing the edges of your panels before assembly a spot of glue in the middle works or a 22 ga nail can work but I feel glue is less lightly to come loose or damage your frame.
    Unless your dealing with plywood or mdf products it's never a good idea to completely glue your panel in due to wood movement problems.
    Oct 2009
    Dennison, MN
    512
    We're talking for a five piece door right?
    I never pre-finish panels. Most homes are so well controlled there isn't much issue with expansion/contraction.
    Don't glue panels in either. Space balls, or one brad at the top+bottom.
    Space balls are dirt cheap. A bag of 5000 is less than $80
    "Do, or do not. There is no try."
    -Yoda
  1. New finish over old
    By Susan Hod in forum Finishing School
    Last Post: 02-04-2012, 01:57 AM
  2. What finish?
    By Kenny Wright in forum Finishing School
    Last Post: 02-24-2010, 02:00 AM
  3. Replies: 1
  4. Finish for bar top?
    By Shane Ricciardi in forum Finishing School
    Last Post: 12-02-2007, 10:38 PM
  5. To finish or not to finish - That's the question!
    By Bruce Shiverdecker in forum General Woodturning Q&A
    Last Post: 01-10-2007, 04:22 AM
Tags for this Thread
