Results 1 to 4 of 4
Thread: water, sweet water.....now
    11,832
    You might recall, a couple months ago I had an emergency situation with water flooding our finished walk-out basement. The finished part is shared with an extra long one car garage we now, laughingly, call my shop. In the shop, right next to my lathe is the well pressure tank and a maze of pipes. When we first moved in here almost eight years ago, I noticed the concrete floor around the tank was a little wet. Paid it no mind believing it was from condensation. In the pipe maze is a whole house filter. From the beginning I had to change the filter every couple weeks. And our water often smelled unpleasant and sulphry.
    Well, the flood revealed the bladder in the pressure tank was leaking. After an after-hours plumbing repair, new tank and about a $1,000.00 tab there is no more water on the floor.
    And, a pleasant surprise, the filter is still in good shape and has barely discolored. And, our water tastes just fine better than ever before.
    We were getting nasties in our water from a small hole in the old bladder that crudded up our pipes and made the water smell.
    Lesson learned: Overlook nothing. If it doesn't look, or smell, right check it out.
    Oct 2010
    South Central Michigan
    25
    huh a pressure take with a hole in the bladder... I think I now know where to look in my fathers house for the same sulfur smelling water. Was the grime similar to charcoal found in fish tank filters?
    13,361
    Our pressure tank had a leak and we noticed it primarily because we were getting 'fizzy' water in the house, and the pump ran way too much...
    The rubber did degrade and left black goo around....
    11,832
    Quote Originally Posted by Andrew Arndts View Post
    Yes, yes, yes. Stinky and ugly.
  1. Water, water everywhere, but not a drop to .....!
    Last Post: 03-11-2013, 05:31 PM
  2. In hot water...not
    Last Post: 04-25-2012, 06:20 PM
  3. Water elm HF
    By Dennis Ford in forum Lathe Project Showcase
    Last Post: 07-20-2011, 09:54 PM
  4. moldy water
    Last Post: 06-19-2009, 10:06 PM
  5. Lotza Water
    By Pete Simmons in forum Off Topic Discussion
    Last Post: 08-20-2008, 11:54 PM
