Results 1 to 10 of 24
Thread: Hanging/Mounting from/on the Ceiling
    Jun 2010
    3,220
    Hello and good day!
    I just got 2 heaters that I need to mount on the ceiling of the garage with brackets. So can you tell me how to do this?
    Are there studs in there that I should screw to? Do they run parallel to the house or perpendicular? Can I mount a ledger board up there?
    Thanks all,
    AKA The Rookie
    - Joists, yes.
    - Your stud finder will serve you well to answer this. Have LOYL leave the room so the device is not confused.
    - If you want. My dad has one of those heaters and just screwed to the joists. They aren't all that heavy but, do have a pull chain, right?
    Jun 2010
    3,220
    - Joists, yes.
    Hmmmmmmm a pull chain....never thought of that.....could I just turn it on and off by plugging it/unplugging it? It's going to have to be on a long extension cord anyway until I get an electrician in there......I gotta have some heat before me or my dog drops dead in there.
    AKA The Rookie
    17,472
    your joist up there wil run the same direction as the rafters do,, or at 90 degrees to the ridge. and should be every 2 ft apart.
    3,132
    Larry i don't know about 2 ft on centers, i'll bet they are 16" on centers.I don't think anything but really cheap starter homes have 2 ft on centers. Could be wrong but with out looking i'd bet on it.
    Long Hill Township, NJ
    467
    I had a female friend at work. She was relating that she did all the maintenance work around the apartment and they needed to hang up some shelf brackets in the living room. She said she got out her stud sensor, found the studs and attached the brackets.
    I asked her if the boyfriend set off the stud sensor. She smiled and said - No he doesn't.
    Cheers
    Jim
    NH
    4,005
    Quote Originally Posted by Stephen Bellinger View Post
    I would not bet on that.
    Stupid hurts.
    Constantine, MI
    7,890
    Mine are 2' OC
    Actually, you're both right. If there is living space above (2 story) the ceiling JOISTS are likely to be 16" OC. If it has attic space above with a truss roof system, 24" OC would be the norm.
    www.wrworkshop.com
    I agree on the 24" on center, my house is semi custom and thats how they are.
    3,132
    Mine are 2' OC
    Rennie Not sure how they build up in her part of the world. But i do know after 30 plus years of building houses i can count on one hand the times i've put any joist 24 on centers. If you put your joist 24 on center you should put your rafters 24 on center also. that is the reason i said what i said about the cheap starter homes. Not saying hers is this way,just would not let anyone do that on my job site.
  1. coffered ceiling
    By Guy Bratt in forum Carpentry and Construction
    Last Post: 02-23-2011, 08:00 PM
  2. A&C Ceiling fixture
    Last Post: 11-05-2010, 01:14 PM
  3. Wall Hanging - IT'S FINISHED and not a wall hanging anymore!!
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 09-21-2010, 03:43 PM
  4. mounting router table top
    By Rex Bloem in forum Jigs and Fixtures
    Last Post: 12-27-2008, 10:46 PM
  5. Ceiling Procedures
    By Robert Englebrecht in forum Carpentry and Construction
    Last Post: 05-23-2007, 05:28 PM
