Results 1 to 8 of 8
Thread: Hollowing Deep and wide
    Palm Springs, Ca
    1,166
    Had most of the last couple days free and cut up and sealed some of the wood I got. They say it is Walnut but it did not look it but smelled like it. Either way I had a chance to put a pc on the lathe and turn it.
    The first pc I put on and turned was a large blank. I used my Monster rig in the beginning but then switched over to my D-arm hollowing rig with a larger bar for the deeper hollowing. I started with a straight bar and 3/16" tip and did alot of the hogging with this bar. Then changed over to a goose neck with tear drop scrapper that I made out of old saw blade. It worked very well but I had to sharpen it several times before I completed the hollowing. The walls turned out very smooth to the touch - and with very light cuts as i hollowed and feathering there was not any need to sand much.
    Question - where can I buy HSS round that I can just cut my own tear drop cutter from ??? Anybody have any ideas.
    Pictures 1-2 :::: 12" wide and 9 1/2" tall was the dimensions of. It has 2 thin coats of tung oil and is drying - then back to the lathe for wet sanding with some more tung oil (maybe 3 more coats or so), then inside to dry for several weeks. Then I will probably buff it with WD and Renissance or spray Laquer for final finish.
    Pictures 3-4 :::: Smaller open mouth vase with a natural edge - ran out of time so i sprayed it with some soapy water in and out and put a plastic bag over it for the next couple days until I can finish it.
    Pictures 5-6 :::: Olive wood vessel - 7" tall and 9" wide - finished
    Attached Thumbnails Attached Thumbnails Vase-2.jpg   Vase-4.jpg   Vase-1.jpg   Vase-3.jpg   Vase-5.jpg
    30,002
    They're all looking good, Dan. That first piece looks real promising. I hope to see finished pics of it.
    NH
    4,003
    Looks like walmut to me
    And they are coming out cool too
    Stupid hurts.
    3,132
    Looking real good from here also.
    Oct 2010
    Abq, NM
    312
    Those are some nice pieces. Love the sapwood with the heartwood walnut. I think it's very complementary. Nice work - happy hallowing!
    mj
    Palm Springs, Ca
    1,166
    Thanks to all.....................
    11,825
    I'll second the walnut with sapwood.
    All lookin' fine from here.
    As to where to get the steel, I would suggest just asking around your local machine shops.
    Westphalia, Michigan
    955
    Not real cheap Dan, but you asked. I have ordered from this company before and found their prices to be the best. MSC industrial supply. They were real fast with the shipping. http://www1.mscdirect.com
    This is the link to their page of HSS, M2 steel round stock:
    http://www1.mscdirect.com/CGI/GSDRVS...00000165943177
    I'm a certifiable tree hugger. (it's a poor mans way of determining DBH before cutting the tree down)
  1. Wide.....Very wide sander for sale!
    By Tom Baugues in forum Classified Ads
    Last Post: 01-25-2014, 03:18 AM
  2. hollowing deep
    By Stephen Bellinger in forum General Woodturning Q&A
    Last Post: 06-16-2010, 01:22 AM
  3. Boring a deep hole for hollowing
    Last Post: 01-19-2010, 07:37 PM
  4. Hello from the deep South . . .
    By Kevin Jaynes in forum Welcome and Introductions
    Last Post: 02-13-2009, 09:24 AM
  5. Replies: 0
    Last Post: 03-27-2008, 01:49 AM
