Results 1 to 10 of 10
Thread: Nova DVR XP Question
    Red Deer, Alberta, Canada
    618
    I've just started trying to create my first open-segment project. My Nova DVR has a very slight play when I lock the indexing pin; it's not much but there is enough play to give me trouble lining up the segments perfectly. Does anyone else with this lathe have any play when the headstock is locked? Or is my lathe an exception? This hasn't bothered me in the past but it sure makes a big difference in trying to line up segments this way.
    I've taken it apart and can't find any way to extend the pin lower into the indexing wheel. I believe if it dropped about 1/16" to 1/8" further it would be tight enough. Any ideas? Any help would sure be appreciated.
    .....Gord
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Contact Tim Geist sent Pm with the info.
    Drew, it's my understanding that Teknatool has changed who is providing their US supports, and that Tim is no longer the go-to guy. Here's a thread Doug Miller posted over on Woodturner's Resource back in October:
    http://www.woodturnersresource.com/c...num=1286860789
    Hey Gord...good to see you.
    Nov 2007
    2,070
    Well that is a bit of a shock. Wish Tim all the best. Thanks for the update Vaughn. Sorry Gord didn't mean to stear you in the wrong direction.
    Goodland, Kansas
    4,834
    Nope my DVR does it to Gord. Just a slight amount. I just turned on a Jet 1642 and it does move to so I don't think it is unusual. My Rikon I just checked moves slightly also.
    Bernie W.
    Nov 2007
    2,070
    Just checked mine and it isn't even worth mentioning the 1/16 slight wiggle that it has. Don't know if that is "normal" or not.
    618
    I admit that the amount of play is very small, however at the outer rim of a 12" bowl that small amount becomes about 1/4" and that's making it very difficult to line up the segments on an open-segment bowl with any accuracy.
    become so uncommon?
    My Woodwork Site
    Mine (1624-44), has had the same play, but just the other day I noticed the index pin won't hold any more. Removing the chuck and the spindle would turn, with the pin engaged. Been trying to get ahold of customer support and no luck so far.
    As I mentioned, I've been having a problem with the index pin not holding. Teknatool returned my call the other day, and I gotta tell ya, they were great. I spoke with Bob Groskopfs, and explained the problem. He was willing to take a unit apart and send me the complete index assembly. I told him not to do that, instead, order the parts because it was not a dire emergency. Well, the next day, Bob called back, he found an empty headstock in their warehouse and examined the working of the index pin. He suggested I remove the acorn nut, then, using needle nose pliers to hold the threaded portion, back the knurled knob off one revolution, and replace the acorn nut. I did it and...problem solved!! Backing off the knurled knob allowed the index pin to go in a little deeper to the holes in the pulley. Bob was extremely helpful. I couldn't be happier with the new customer service. Gord, you might try the same thing on your lathe, it might tighten up some of that slop.
    Nov 2007
    2,070
    Thanks Richard that is good to know just in case mine acts up. My biggest problem is remembering to unlock it before turning that machine on. yes I have been known to do a stupid thing from time to time.
  1. Nova Soft Jaws question
    By Tim Browne in forum Turning Tool Questions and Show & Tell
    Last Post: 10-05-2009, 08:23 PM
  2. Nova DVR-3000 and Nova 3000 bed extention close out
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 12-20-2007, 04:27 AM
  3. Nova DVR-3000 and Nova 3000 bed extention close out
    By Stuart Ablett in forum Hot Deals
    Last Post: 12-09-2007, 02:53 AM
  4. Nova lathe question
    By Clark O'Neill in forum New Tools
    Last Post: 12-02-2007, 03:50 PM
  5. Nova DVR XP
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 04-02-2007, 03:06 AM
