Results 1 to 10 of 14
Thread: 8 sided pyramid math problem
    Mar 2010
    Maplewood, NJ
    78
    It's too much for my meager math skills.
    I'm trying to build a birdfeeder for my wife for Christmas that replicates the gazebo-shaped addition off the back of our house.
    The addition has an eight-sided roof that comes to a point in the center, kind of like a squat steeple.
    I can calculate the pitch of the roof easily enough, but it's going to be made out of eight pie-wedge shaped pieces of 1/2" ply, and the sides (interior edges) of those pieces need to be beveled to fit tightly. I don't have a clue as to how to calculate the angle of that bevel.
    A friend sent me a solution that might be perfect, except I don't understand trigonometry, so I have no idea what he's talking about.
    Something tells me there's an easy way to do this. I would bet that millions of such shapes have been created by craftsmen with no knowledge of trig whatsoever.
    Here's the basics: The roof of the feeder will be 14" across at the base. It will be 3.5 inches high at the center. At what angle do I need to bevel the pieces so they'll fit together at that pitch?
    Thanks!
    9,054
    NH
    3,990
    That's some spiffy math you got there Glenn
    If it was me I would just set the table saw blade at some random angle and rip out some test pieces. If they worked great if they didn't I would adjust according.
    Way less stressful than doing all that math just to find out that the angle it came up with is wrong and you need to adjust the angle just a bit anyways.
    Stupid hurts.
    SE Minnesota
    2,497
    I did it graphically in SketchUp in a minute or so. It says that the tablesaw blade needs to be tilted over at 9.854°. If you want the illustrations, I can post them.
    NH
    3,990
    And I was guessing some where between 5 and 15
    Stupid hurts.
    SE Minnesota
    2,497
    Yeah, but you were using your fingers and toes.
    NH
    3,990
    Quote Originally Posted by Dave Richards View Post
    Nope no math just dead reckoning.
    To be honest I prolly would have put a 5 or 6 on the first time. When that didn't pan most likely would have jumped to 10. Than had to back it off just a smidgen to make your 9.854 on the third try.
    Just like field artillery Shoot one low. shoot one high. Than shoot one right down the middle
    Stupid hurts.
    SE Minnesota
    2,497
    That's prolly the best way, too.
    Here's what I got.
    8,528
    or set the angle for 10 degrees and adjust the side the slight bit to accommodate, so what if it a 1/3 of and inch or so higher or wide ?
    SE Minnesota
    2,497
    That's what wood filler is for anyway.
  1. Pyramid Lake Fishing
    Last Post: 02-26-2016, 10:50 PM
  2. Math Algebra Guru
    Last Post: 01-18-2011, 03:02 AM
  3. math help
    Last Post: 12-04-2010, 06:41 PM
  4. math question
    Last Post: 11-24-2008, 11:31 AM
  5. Math Skills
    Last Post: 05-03-2008, 10:31 PM
