Bruce Shiverdecker
In Memorium
- Central Illinois
I'm sorry, I'm gittin' oldish an don't see things as straight as I useta. I'm gonna guess that the inside is causing troubles. I have always told my students not to use a spindle gouge on the inside of a bowl, even though some well known turners say otherwise. The thing they don't tell is that they do not use a standard grind. If you can do spindle work, working the outside of a bowl is very similar. If you don't have one yet, try grinding one of your bowl gouges in an Elsworth or Irish grind. It is much more forgiving.
Hope this helps.
Bruce
Hope this helps.
Bruce
