Results 1 to 10 of 21
Thread: old house and elektriks ?
    11,833
    The house my daughter moved into is a 1950's vintage. Bathroom are interesting. They still feature the old ceramic tile from that era. In one there are three different shades of pink and two of green. It is nearly barfable to look at too long. The other is an un-appetizing combo of pinks and dark purple. I get queasy just looking at it.
    Enneyhow, my one big concern with the house is the electrical system. Some outlets are labeled "no ground", some have no juice but record a very slight amount with a tester, others seem OK. The lone, small, fuse box strikes me a possibly borderline adequate. BTW, the house is 1600-1800 sq. ft., not tiny. I didn't even know if these types fuses were still made but I bought her extras at the BORG.
    Wadda y'all think?
    WOW... Dijavu all over again... I haven't seen anything like that in Years. My first concern is are the right size fuses in the circuit. hopefully no on put a 30 amp in where a 20 or 15 should go. Also 6 fuses for an 1800 ft'sq. house another
    Villa Park, CA
    1,407
    I know this is a big job, but I'd seriously consider upgrading the electric system in the home. The house probably has a limited amount of outlets, lights, and other electric service. When that happens, people tend to use extension cords, or do jury rigged wiring, to get the service they need. Of course, they overload the circuit and then they put in a larger fuse, more than the wiring was designed for. Then you have a fire.
    If the house is one story and has a basement or crawl space, the new wiring can be run without horrible trouble or cost.
    Mike
    Ancora imparo
    Frank after giving this some thought, I believe you daughter is renting this house and if that is the case I would advise two things.
    1. Smoke/CO2 detectors
    2. Lots and lots of renters insurance.
    new york city burbs
    10,188
    mr. Henderson is probably spot on.
    My house had all those old type screw in fuses. It was inadequate for my home and I had it replaced.
    The garage, I didnt update till this summer. I used those old screw in fuses for 4 years running all my machines all the time, and never had a problem until I started blowing fuses with my dust collector and planer running together.
    My electrician just bypassed the box, Im keeping it on the wall because its not in my way, but put a new box above it.
    the house is probably 100 amps.
    10,604
    I haven't seen a fuse box in years. I remember my dad taking pennies and putting them in the fuse box then screwing in the fuse when the circuits overloaded and blew a fuse
    Smoke detectors, fire extinguishers, flashlights, in every room, and like Don said lots of renters insurance. Oh ya, lots of extra fuses. As soon as she uses her hair dryer while brewing coffee she will need some.
    +1 on a complete upgrade...if not possible...+1 on renters insurance and smoke/Co2 detectors. Not safe the way it looks in the pictures
    13,453
    Frank I know you and electrics don't get along. Might be worth paying an electrician for an hour or two and have him pull the cover to make sure that the right fuse are being used for each circuit, also trace them and see what's on each and get the box labeled with what the fuses support.
    If you want to check yourself, pull the cover and look at the wire sizes. 12 gauge shouldn't have anything larger than a 20 amp and 14 gauge shouldn't have anything larger than a 15 amp. Come to think of it, it's possible the house has aluminum wiring, so those fuses may need to be down one size for each.
    I agree with the insurance, smoke detector, and c/o 2 detector advice.
    5,322
    ...Might be worth paying an electrician for an hour or two and have him pull the cover to make sure that the right fuse are being used for each circuit, also trace them and see what's on each and get the box labeled with what the fuses support...I agree with the insurance, smoke detector, and c/o 2 detector advice.
    Aren't those the "Type S" fuses that have different base sizes for each rating, so that a big fuse can't be screwed into a circuit designed for lower amperage? I seem to remember having them in a house I rented back in the late sixties. House was built in the mid/late fifties.
    13,453
    Hard to tell from the pic, but that looks like the older style fuses to me, look about like a light bulb base, all the same size. Have to let Frank verify.
    Edit: I zoomed in and it looks like they are TL fuses, which are all the same size screw base, so one could put the wrong size in a socket. They do sell adapters to retrofit this type of box to use the "S" type fuses though.
  1. A dog house with my son (log) wip
    By Eric Black in forum Flatwork Project Showcase
    Last Post: 02-20-2015, 12:10 AM
  2. me and elektriks
    Last Post: 08-07-2010, 03:05 PM
  3. One Log House
    Last Post: 08-08-2008, 11:34 AM
  4. New old house!
    By Kirk Constable in forum Off Topic Discussion
    Last Post: 07-16-2008, 02:41 AM
  5. Are there any house painters....in the house?
    By Greg Cook in forum Carpentry and Construction
    Last Post: 09-17-2007, 10:02 PM
