Results 1 to 10 of 27
Thread: Got a planer problem
    Honolulu, Hawaii
    1,103
    Hi everyone. Hope you got to see the lunar eclips. We are socked in solid here, so we missed it.
    My planer problem is with the feed rollers on my Delta 22-540 12" "lunchbox", which doesn't see a lot of use and is like new yet. The rollers are not gripping the wood and I have to push or pull the pieces through. The rollers are clean and in good shape and are turning. The springs have plenty of tension so the rollers are contacting the wood pretty well. The stainless bed plate is clean and has been waxed too. The wood pieces have been run through my jointer so the down side of the 5" wide boards are clean and smooth. Still, most of the time now, I have to help the wood through.
    Who else has had this problem? (I know I can't be the only one), and what did you do about it? Seems as if the roller rubber is not "biting" the wood surface.
    Solutions or suggestions? I cannot afford to replace parts just now, and a new planer is out of the question.
    Thanks for any help.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    5,533
    Tony,
    when my DW734 gets that way, I look to the blades, not the rollers, sharp blades usually clears that problem.
    -Ned
    Tony, you say the rollers are clean, but I find if I wipe them down with denatured alcohol before it seems to make the more grippy. (I do the same thing with my jointer push blocks and Grrripper on the tablesaw.)
    Ned's suggestion of making sure the blades are sharp is also a good one. I've had that dog bite me before, too.
    13,361
    Quote Originally Posted by Ned Bulken View Post
    Tony,
    +1 on checking the blades. Dull blades can make it tough for the planer to pull the wood through...
    +1 for what Ned said
    Sep 2007
    Plainwell, Michigan
    4,857
    Put a coat of wax on the bed, that will also help it go thru easier
    Dec 2008
    Santa Claus, In
    4,779
    Second, the wax the bed.
    11,833
    I came in late.
    Third it, wax the bed.
    Honolulu, Hawaii
    1,103
    Hi people, Thanks for the suggestions. The blades were flipped over the last time I serviced the planer. It doesn't get that much use, but the cutting edges should be just about new. I wrote that "The stainless bed plate is clean and has been waxed too." I'll do it again to see if it helps. I will also try the alcohol wipedown as Vaughn said.
    Thanks a lot. I will see what happens.
    Aloha, Tony
    Floydada, Tx
    1,941
    Depimg om the wood and the way it was stored can dull knives very quick. Wood that has been sitting on the ground or in a barn can get alot of grit in/on it and basiclly sand the blades dull. Try the new blades and it sshould fix it.
  1. DW735 Planer problem UPDATE 1
    Last Post: 10-19-2014, 03:08 PM
  2. Dewalt 733 Planer Thicknesser Problem
    By peter nash in forum General Woodworking Q&A
    Last Post: 09-02-2011, 01:28 PM
  3. Planer Problem
    By Jim Sparks in forum General Woodworking Q&A
    Last Post: 06-03-2011, 08:46 AM
  4. Parks No20 Planer Feed Problem
    By Doug Bury in forum General Woodworking Q&A
    Last Post: 10-13-2008, 09:13 PM
  5. Problem with Delta planer
    By Bill Simpson in forum New Tools
    Last Post: 01-15-2008, 07:58 PM
