Results 1 to 10 of 16
Thread: Sprayer Question
    Sarnia, Ontario, Canada
    55
    Sprayer Question
    I received a Earlex 5000 today as a Christmas present.
    My first question (probably there will some number in the future) is how long can you leave the finishing media in the gun's container?
    Thank you
    Rod
    Rod
    Sarnia, Ontario
    17,474
    i have heard of it being left in there for months but i dont.. i would suggest yu drain out the left over and run the appropriate thinner threw it to get it clean then yu can leave it and not worry about is it good or is it bad.. i use gravity feed and it has thinner or material in it till the job is done..
    NH
    4,006
    A lot of the time the material your using will say on it what the pot life is.
    Stupid hurts.
    13,361
    I tend to shoot, then clean, every time... I'm not a pro, so most likely if I didn't, the jets would get gummed up. I keep an empty pain can around to shoot the excess cleaner into, then take that to the Hazardous materials dump event whenever they have one (Not often enough here in Nevada).
    Floydada, Tx
    1,941
    I will leave lacquer in the gun till the job is done. At most two weeks. Poly needs to be cleaned out ASAP. It will plug everthing up. 3M sell a kit that allows you to take the cup off and store the materail in the cup. This saves alot of time on clean up.
    Apr 2009
    Outside the beltway
    5,259
    Main thing you want to remember to stir up the finish in the cup before spraying if left in for any length of time.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    55
    Thank you for answering my question
    Rod
    Sarnia, Ontario
    Woodstock, Ontario, Canada
    719
    Quote Originally Posted by Al killian View Post
    Poly needs to be cleaned out ASAP. It will plug everthing up. .
    Yes, something I learned recently! I prefer lacquer, way easier to use.
    hobby woodworking since 1972
    Floydada, Tx
    1,941
    I like lacquer for several reasons. The two top are one quick drying(I hate waiting)and two, when done using it, dump out the gun and let the gun soak in a bucket of clean/thinner.
    Thomasville, GA
    5,998
    I have one gun that I use almost exclusively for shellac - sealing and top-coating depending on what I'm doing. I only do a major cleaning on it if I need that sprayer for something else. As long as I keep shellac in it, it pretty well cleans itself as soon as I pull the trigger.
    If I'm spraying lacquer, I use a different gun. The same rule as my shellac gun generally applies with the exception that, when I complete the project, I clean the gun because I also use it for other finishes.
    Bill Arnold
  1. detail hvlp sprayer
    By John Daugherty in forum New Tools
    Last Post: 01-18-2015, 04:04 AM
  2. HVLP Sprayer
    By Tom Clark in forum Classified Ads
    Last Post: 03-11-2014, 08:30 PM
  3. Garden sprayer?
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 08-01-2011, 10:21 AM
  4. Rockler HVLP Sprayer
    By Tony Maio in forum Finishing School
    Last Post: 01-08-2011, 08:00 PM
  5. Recommend a sprayer?
    By Dan Birnbaum in forum Finishing School
    Last Post: 06-01-2009, 05:30 AM
