Results 1 to 10 of 18
Thread: Making Rail & Stile Glass Doors.... Need some help....
    Early in the new year I will be tasked with building a new stand up cigar humidor for the liquor shop. The cash register area is going to get a $50,000 facelift, and part of that will be a new cigar humidor. We are not paying for this, one of the tobacco companies is We are also getting a new sign for the shop out front too. They were going to provide humidor, but it was a particle board and plastic piece of poor quality junk that I would never put quality cigars into, they would smell like plastic and glue in a week
    The new humidor will be kind of like a China Cabinet, if that makes sense.
ID:	52697 Click image for larger version.
ID:	52699 Click image for larger version.
ID:	52702 Click image for larger version.
    Some ideas.
    My first question is can anyone recommend a rail and stile bit set for glass doors?
    I'm looking hard at the new Freud set, this one >> Freud 99-763 << with the optional cutter for glass doors, I'm not sure if this is any good, but I figure it is not bad.
    Any opinions out there?
    17,474
    Thanks Larry!
    Do you have that set, or have you used it?
    Now I have to find a shop that will ship to Japan...
    Floydada, Tx
    1,941
    I dont use a specail it. I use the profile I like, then will take a extra pass to remove to back part of the rail and stile. Then all I do is use silicon to glue it into place and add a small trim pice onto the back.This way it is easy to remove the glass if/when it gets broken.I watched a wiser cabinet maker use this method.
    17,474
    Thanks Larry!
    i have sommerfileds set when they were orange,,and made by cmt. i used it on the blotchy box that came out ok i think.. and have made some other doors with it.
    Thanks for the feedback Larry.
    Alan, I thought about that too, but the rails and stile bit set I do have, I don't like the profile for this job, besides, the price of the new bit set will be partial payment for my labour, so I am getting a new bit set
    Looking at a decent made in China, shipped to the US humidor of this type, will easily set me back $2500, so even with the price of the tooling I'll buy, the wood, and the humidification device, it will be way, WAY below that amount. The Monster-In-Law gets another great deal
    I may go for the Freud set, as I can get it at Rockler and they have a few other things I want on sale right now.... ah a few other things I "NEED"
    Oct 2007
    Pacific Northwest
    59
    Most glass sets that I have seen do not have very good glue area in the coped joints, unless you also dowel. I build glass doors like Al to get better strength. Silicone also stiffens the door using the rigidity of the glass, so they resist sagging over time.
    new york city burbs
    10,188
    too bad youre not here, Id give ya all the spanish cedar you need.
    Oct 2009
    Dennison, MN
    512
    A seperate rail and stile set is a waste of money for glass doors, unless you're banging out a rediculous amount of doors.
    I cut the backside out of the rails on the tablesaw then glue up the door like any other minus the panel. After its been through the widebelt I take a rabbet bit to cut most of the backside out on the stiles, then finish it off with a flush trim bit for laminate, (the non-bearing type)
    Boom. Glass door.
    Buying a separate set of cutters will never pay.
    "Do, or do not. There is no try."
    -Yoda
    NH
    4,006
    +3 on getting or using a regular door set and cutting the back. Depending on the end use I have cut a strip to fill in behind the glass. Or installed it just as you would in a window with glazing points and putty.
    Stupid hurts.
  1. Stile and rail panel door question
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 03-07-2013, 03:45 PM
  2. Rail and Stile
    By Steve Southwood in forum Designs, Plans and Sketches
    Last Post: 08-09-2011, 08:56 PM
  3. seeking rail & stile bit set
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 04-27-2009, 08:51 PM
  4. Rail and Stile profile cutting
    By Matt Dunlap in forum General Woodworking Q&A
    Last Post: 05-12-2007, 10:00 PM
  5. Rail and Stile Question
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 05-10-2007, 07:04 PM
