Results 1 to 10 of 13
Thread: Awl-grip
    Apr 2009
    Outside the beltway
    5,255
    Awl-grip
    a product called Awl Grip ? I'll have to look it up. Is this a product for high end rubbed finishes ?
    My brother uses it for refinishing yachts and says he uses it on classic cars.
    Can this product be rubbed out ?
    Dose it look plastic ?
    Plastic looking finishes tell me the finishers likes short cuts LOL
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    5,321
    Jamestown Distributors has it. Thay say it's really good for above the waterline finishing of classic boats. A bit pricey at $47.00 a quart, but likely worth it if JD says it is.
    There's also Epifanes...
    Apr 2009
    Outside the beltway
    5,255
    I will check that out Jim. I know what is best for wood and what give the WOW to the customers I will need to get a qt to try out before on Veneers and hard wood's. I hate working with new products there is always the trail and era period, thou usually very short just adds one more to the list.
    I did find this description. From just reading this I see plastic !
    There are two types of Awlgrip products. The original Awlgrip is a true polyurethane made with polyester resins. This system when properly applied creates the most durable long lasting film finish in the marine environment yet can be tricky to repair.
    Awlcraft 2000 is a acrylic urethane created with acrylic resins. It is a great product which is easier to apply and repair but not quite as durable. Both products have excellent gloss and long term color holdout.
    17,472
    dave in all the fancy rides i have been in the wood does look like plastic, mirro finish and no pores showing at all..i dont think Henry Ford had that kind of finish in his cars but maybe
    Apr 2009
    Outside the beltway
    5,255
    Larry filling the pores is no problem with grain filler. I like the idea of a oil hand finish. like I put on my Curly Maple flint lock. That finished is 25 years old and has been used a lot. Hand rubbed 100% tong oil wil about 25 coats. I may have to find a quicker way of building the finish to be cost effective.
    5,321
    I think all the old 'woodies' likely used a version of what's now called SPAR varnish as their original finish. An oil finish just wouldn't hold up well on a car or boat. Even the best wooden boat 'bright' finishes (like Epifanes) require at least an annual re-do.
    From the sound of things, you're likely getting into the classic car restoration biz, where the emphasis is on ORIGINAL, so you may not even be able to use the modern stuff if it diminishes authenticity. I'm sure you'll fine out what's what as you delve deeper into this.
    Dec 2008
    Santa Claus, In
    4,779
    Quite posting pictures of the Curly flintlock, drives me nuts
    17,472
    Quote Originally Posted by Steve Southwood View Post
    you can relax steve it really isnt as purty as it shows in the pics......
    ITS WAY BETTER
    Dec 2008
    Santa Claus, In
    4,779
    You're killing me
    I just re finished and painted the bottom of a 32 year old sailboat. It had only had one bottom paint job and that was from the factory. I sanded off all the old "Smurf" blue bottom paint and that opended the gell coat of the fiberglass. I was told that it had to sealed. I had thought about using an Ablative Copper infused bottom paint. Since I will only have the boat in salt water maybe a couple of weeks to a month. I reasoned that I really didn't need an anti fouling paint.
    I called a Yacht designer friend in Fl. and he recommended a paint called EasyPoxy from Petit, it is available from most marine supply houses.
    I bought a gallon and painted the bottom http://sports.webshots.com/photo/262...70055750hUkpTu
    I painted below the water line. Above the line I just buffed out the fiberglass.
    I also changed the mustard yellow color in the interior to white using the same paint.
    I am not a painter, I didn't spray it on, just roll and tip. It went on like cream best paint I have ever used. We put the boat into the Mississippi for 6 weeks and got no zebra muscles on it and only a mild coating of slime. It washed off with warm water and soap. I love this paint. It is about $90 per gallon.
  1. Pistol Grip Handsaw.
    By Rob Keeble in forum Neander Woodworking Q&A
    Last Post: 11-04-2013, 02:10 PM
  2. Help me get a grip
    Last Post: 09-16-2013, 12:19 PM
  3. Just a soft grip pen
    By Brent Dowell in forum Lathe Project Showcase
    Last Post: 07-29-2013, 03:50 PM
  4. grip for the elderly?
    Last Post: 09-23-2007, 12:42 AM
  5. I got the Grip-Tite
    By Allen Bookout in forum General Woodworking Q&A
    Last Post: 05-11-2007, 08:04 PM
