Results 1 to 6 of 6
Thread: Tenon problem ??
    Palm Springs, Ca
    1,167
    Tenon problem ??
    Today I made another vase like turning and when I reversed it to work on it the tenon broke off. I am going to let it dry for a couple weeks and then ill need to figure out a way to remount it in order to sand the inside and outside. The problem is I made the wall on the foot area (outside bottom)very thin and I do not think it it will hold in expansion mode tightly (loosely yes but it would break it tighten up).
    So, my thought was is to make a small 2x2 square block and glue it to the bottom - then sand and part off the glue block when im done.
    Anybody have another solution ?????
    Attached Thumbnails Attached Thumbnails Tennon-1.jpg   Tennon-2.jpg   Tenon-3.jpg   Tenon-4.jpg
    you will have a real problem getting the block centered and the piece will wobble very badly. I'd just sand it off pf the lathe and call it good.
    Goodland, Kansas
    4,834
    I agree with Don especially if the wood is green. By the time you get your block ready it is already going to be out of round. I have never had any luck doing that. Myself I just toss'em because to me life is to short to turn bad or broken wood. You could let it dry, sand it and finish it.
    Bernie W.
    11,828
    Don't chuck on soft, spunky, sap or green wood. Doing so can result in flying objects.
    DAMHIK.
    30,008
    There's no need to have the glue block perfectly centered as long as you mount the piece reversed and turn the glue block round before chucking it. That said, if the bottom or walls are thin, there's still the risk of breaking it when parting it off. I'd probably just try to sand it off the lathe and call it good.
    Palm Springs, Ca
    1,167
    Thanks to all and I will post the final outcome in a couple weeks - and tell how I decided to do it....................Dan
  1. Apron tenon?
    By larry merlau in forum Designs, Plans and Sketches
    Last Post: 12-30-2012, 03:11 PM
  2. Grizzly tenon
    By Bill McQueen in forum General Woodworking Q&A
    Last Post: 01-21-2012, 02:55 AM
  3. Tenon Jig
    By Steve Southwood in forum Jigs and Fixtures
    Last Post: 12-31-2009, 02:59 AM
  4. Tenon shoulder problem-looking for suggestion
    Last Post: 10-03-2008, 10:45 AM
  5. Tenon vs. Loose Tenon
    Last Post: 04-13-2007, 11:18 PM
