Results 1 to 8 of 8
Thread: moisture meter
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    moisture meter
    I am looking to get a moisture meter and I really don't much about the 2 types. I guess That I don't really need a fancy unit, just something that works. I would like to know what you guys are using and if it is pin type or pinless.
    Central NY State
    3,374
    I have one of these, and it seems fine. There are fancier pinless ones, but at the price point this one was, it seemed like a good purchase.
    http://www.leevalley.com/en/wood/pag...=1,43513,45788
    Jan 2011
    Tacoma, WA
    274
    Pinless is painless...
    I have the pin-less type, a wagner mmc 220. I like it's accuracy and its range. I can check the moisture content right through a finish (even plastic) with out leaving a mark. Also it checks a larger area and deeper than most pin type. The only down side is the price. There are less expensive meters by wagner, just look on-line. I've used this for flooring, for picking out boards at the lumber yard etc. Just remember to adjust for species specific gravity. (must be done with both pin and pin-less type of meters). You should receive an instruction book with the meters that will give you that information.
    Bellingham
    2,449
    Aug 2010
    Knoxville
    10
    I use a pin type.
    I'm a home inspector, so I have some pretty high end moisture meters, one of which is both a pin type and pinless.
    I really don't think a pinless type is the best one to check for moisture in boards.
    welcome Jack
    Jeff Horton is in the same line of work as you.
    Oct 2010
    Rittman Ohio
    13
    My brother bought me one from Harbor Tool and Frieght.
    http://www.harborfreight.com/digital...ter-67143.html
    Tellico Plains, Tennessee
    4,351
    I don't know from nothing about the moisture meters, but suspect I could use one... I just saw a couple in the PSI catalog that were reasonably priced... both were under $50 if I remember correctly..
    Chuck
    Tellico Plains, TN
  1. Moisture meter recommendations
    Last Post: 01-01-2012, 04:09 AM
  2. Moisture Meter
    Last Post: 07-17-2011, 02:40 AM
  3. I need a moisture meter
    By John Daugherty in forum New Tools
    Last Post: 03-18-2011, 12:32 AM
  4. Concrete moisture meter...
    By John Pollman in forum Off Topic Discussion
    Last Post: 05-09-2009, 09:53 PM
  5. I need a moisture meter I can trust.
    By Kevin Mishler in forum General Woodworking Q&A
    Last Post: 01-04-2008, 03:43 PM
