Results 1 to 10 of 11
Thread: Does anyone steam their own wood?
    Jan 2011
    Tacoma, WA
    274
    Does anyone steam their own wood? I would like to build my own steamer, the local spa is really starting to get annoying with their wining every time I bring my wood and forms down to their steam room!
    I was thinking of using a pvc pipe with a drain in the bottom on a slight downhill slant and a small vent on the up hill side and use an old clothes steamer for the source. Does anyone have a better idea or tips?
    Thanks!
    Brian, Although I have never done it there are a number of folks on here who have. I am sure you will get a number of answers
    Floydada, Tx
    1,941
    Leevally sells a kettel just for for steaming. Use a peice6" pipe with a end cap or a peice of wood with hinge
    Dec 2008
    Portland, Oregon
    1,898
    I did a project a while back and it worked ok, Here is a link to the post,
    Jesus was a Woodworker
    12,260
    Of course there is also Chucks way you can see here when he makes his handles for his fantastic beer mugs
    http://familywoodworking.org/forums/...8&d=1267231881
    here is the thread link
    The Heart of Dixie
    4,268
    I bend a lot of thin strips and I just use a heat gun on it. No water. It's the heat not the moisture that allows it to bend. But if you doing thicker pieces that need to steam for a long time then the heat gun probably wouldn't be suitable.
    Custom built boats and Kits
    I've done a moderate amount of steam bending, but rather than try to explain it, I'll point you to a booklet that you can download from Lee Valley. It is great, like most everything they do.
    I did the PVC pipe and it worked OK, but if I were doing it regular like, I'd build a proper plywood steam box, the PVC is not fun to handle and it actually sagged on me a bit in the middle.
    Jan 2011
    Tacoma, WA
    274
    Thanks for the info!
    Thank you much! I will start a steam box here next week and give it a try! (maybe I can steam my lunch while I wait and have it keep my coffee warm too! Well, maybe not. How does cedar flavored coffee sound?)
    Brian
    I have a 6" dia chunk of schedule 80 pvc, which is a lot more robust than the regular stuff. Regular pvc will sag, and I stopped using it because of that. Be careful of making the box too big because it can be difficult to get the whole works hot and keep it that way.
    I made a wooden trough out of some plywood to keep the pipe from sagging before I got the thicker stuff.
  1. Steam bending for boat building with a clever non steam box idea
    Last Post: 04-27-2015, 04:50 PM
  2. Some Steam punk
    Last Post: 04-29-2014, 07:06 PM
  3. Wood Steam Engine
    By Hubert Carle in forum General Woodworking Q&A
    Last Post: 08-31-2011, 12:11 AM
  4. Steam
    By peter blair in forum Turning Tool Questions and Show & Tell
    Last Post: 05-15-2011, 11:56 PM
  5. Steam Bending ?
    By Don Baer in forum General Woodworking Q&A
    Last Post: 08-04-2009, 04:56 PM
