Bill Simpson
Barry, I've never tried Gorilla Glue because, what I've heard, is that it expands while curing, thus opening the joints.
Again, this is what I've been told by others and read in books (mags)...... so I never tried it.
Tony, I use gorilla because of the concerns you mention. With loose joints and worn joints it is a great fix for old furniture repairs. Th expansion of the foam works into cracks and fills open areas. But it does require clamping to keep from pushing the joint apart. (just remember to NOT put any on the ends of Tenons and Dowels so it can't "Push out")
As for the mess, It is a matter of learning to be cautious of the spillage and to use small amounts of glue on one portion of the joint and moisture on the other to start the chemical reaction and the hardening process. (I wear Nitrile gloves)
As for Laminations with Poly glue, the working time is a plus and if you apply the glue to only one side of each laminating piece they will wait for you to finish applying to all the pieces. Spray a fine mist of clear water on the other side, just as you assemble the plys and clamp into the form. I like to use Wax Paper when I use Poly glue as it will not adhere and it protects the surrounding surface from the ooze of the foam during curing time. I keep any poly glued pieces in the clamps until the foam is hard and brittle, that way I know the process is completed.
