Results 1 to 10 of 12
Thread: Slat Wall Question
    13,361
    Slat Wall Question
    I've been looking at the link Chris had posted about a DIY Slatwall system.
    It looks interesting to me. Just wondering if anyone here has made anything like that to use in their shop or if you have a commercial slatwall.
    I'd be very interested in any pics or comments you have about them.
    5,321
    Looks interesting - kind of a variation on a French cleat.
    If you used a French cleat system, cut at a 45° angle, you could make it in one piece (both on the wall and the hung item) and save a step (and also some material).
    13,448
    I'm looking to do that system in my shop, but like Jim mentioned, using a french cleat instead.
    I may incorporate a pin that can be pushed in below the lower cleat to keep the 'organizer' from coming off the cleat. Kinda like Glenn does on his cabinets
    13,361
    That's a great idea. I think the thing that I didn't like about the link was having to cut all the ply, glue it together, relieve the back of one side...
    There'd be a lot of pieces to put together to make all of the custom holders, but that might be part of the appeal. Making little cabinets to hold sandpaper, etc. that could be pulled off, taken to the work and then put back...
    13,448
    Here's the pin idea that Glenn uses.
    http://familywoodworking.org/forums/...31&postcount=4
    new york city burbs
    10,188
    This thread is why I feel like a total outsider both here and in the rest of the woodworking world.
    If I wanted wall space to hang things, its either nails or FREE PEGBOARD.
    2,784
    There are router bits to make the slat wall slot without having to make separate pieces. My problem with the MDF slat wall material, and I have it in my shop, is that the MDF can come apart. I have seen aluminum channel that works with slat wall hangers that you then cut the wood to go between them. I think if money was no object, that is the way I'd go. But I do like being able to scoot a hanger bracket down just a tad so the next new object clears those around it. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    NH
    4,005
    Some thing like that has now been put in the some day project for the shop
    Thanks Brent just what I needed another shop project.
    Stupid hurts.
    I've been a proponent of the cleat system for awhile now. The system in the article is a bit over complicated IMHO as a french cleat does quite well. The pics are from 2008 - 2010 and the instant versatility has allowed me to re-arrange as required or desired many times.
    Attached Thumbnails Attached Thumbnails cleat-wall.jpg   cleat-wall-042008-1.jpg   small scrap storage 003-sm.jpg
    Chris Hatfield is offline Former Member (by the member's request)
    Aug 2010
    380
    That's what I started to think as well - a bit overcomplicated. I'm doing a 5" crosscut then bisect with a 45 degree rip to keep things simple.
  1. I was given this wall
    Last Post: 06-13-2012, 01:00 PM
  2. question about attaching raised panel sections to wall
    Last Post: 06-11-2011, 07:44 PM
  3. Wall Hanging - IT'S FINISHED and not a wall hanging anymore!!
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 09-21-2010, 03:43 PM
  4. Magnetic Wall Question
    By Travis Johnson in forum Designs, Plans and Sketches
    Last Post: 02-29-2008, 05:10 PM
  5. Wall question
    By Allen Grimes in forum General Woodworking Q&A
    Last Post: 03-06-2007, 03:03 AM
