Results 1 to 5 of 5
Thread: Adapting a carbide finish cutter.....
    Oct 2010
    Abq, NM
    312
    When Vaughn was here last week I tried his easy rougher and sliced my fingers (not bad) wiping off the dust etc, from the cutter. Then I realized I was planting my DNA in his foam handle with my blood.
    I like my hand held hollowing tool made by Jeff Nicol and thought I have to get some carbide on there. Jeff sent me a round tip and a square one too, made from old saw blade, but I have not come up with a good jig to sharpen them. Yes, I have the mini monster but I still like using this tool to smooth out HF's.
    I adapted it with just a small washer under the cutter and used the screw that came with my rig (larger diameter) and tightened her down. $18 +tax.
    Cheap and easy carbide finisher!
    30,002
    Cool. You're gonna love the EWT carbide cutter. I've got the unhandled Ci0, and the shank fits into the Monster rig. Works great for finishing cuts.
    Oct 2010
    Abq, NM
    312
    I thought I would do the Ci1 square rougher and the R4 while I was in tinkering mode. Hope to give them all a spin this weekend. I had to make a little more room for the cutter and thought I might want to put a flat spot on both holders to help prevent slipping and turning. These will fit in my mini monster as well!
    Attached Thumbnails Attached Thumbnails squareup.jpg   flatspot.jpg   installed.jpg
    Palm Springs, Ca
    1,166
    Let us know how it works sounds like a good idea
    Goodland, Kansas
    4,834
    Sounds like a plan. I use the hunter carbide cutter in both my monster units.
    Bernie W.
  1. Carbide Processors - Source for Carbide Inserts
    Last Post: 12-18-2015, 03:20 PM
  2. Kudos to Carbide Processors
    Last Post: 01-29-2015, 01:53 AM
  3. Sharpening carbide tools
    By Jim Hager in forum General Woodworking Q&A
    Last Post: 12-28-2011, 05:30 PM
  4. carbide tipped rougher f/s
    By John Daugherty in forum Old Ads
    Last Post: 01-21-2010, 12:19 AM
  5. VS adapting
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 09-04-2008, 06:43 AM
