Results 1 to 10 of 17
Thread: smaller gun??
    17,474
    smaller gun??
    pictures and links to what yu use to get into tight spaces to spray finish..
    am looking to get a detail gun, but they are sayun that they have a 1.1 needle and wont that be to small to spray lacquer and the finishes we wood workers use? the gravity feed gun i know use has a 1.4 needle and i have to thin the finish to get it to go threw right.. yet tod has a 2gt pressure pot and he can spray straight stuff, dont know his needle size.. am looking at a reasonble system am not looking at a devilblis quality yet? maybe i should be though karl are yu listening?
    Apr 2009
    Outside the beltway
    5,259
    Larry I have a HVLP system with a 2 gal pot I'll sell ya. I do not use it any more. It needs new hoses. I only use it for 3 years and decided to go with the cup guns. The cups just take a little practice to get use to and also using the different angles of spray. If you get over spray brown paper bag the over spray and then just wax.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    17,474
    dave if yu dont need a two gallon pot i surely dont either i dont spray near as much as yu do ... i am just needing to get in that small spaces better.. any idea why the other setup i told you about with the 2 gt pot would squirt so heavy would a needle being to big cause that on thin material? or is a pressure issue?
    Apr 2009
    Outside the beltway
    5,259
    Both pressure and needle size. It sounds like you need a smaller needle. Are you spraying with a turbine ? Or from a compressor?
    Apr 2009
    Outside the beltway
    5,259
    I'm in and out of the office all day. I have a leather top with tooling I need to repair the tooling. Very small brushes and very time consuming. The good part of this is the tooling was done with paint not gilding.
    17,474
    compressor dave, the turbine is in storage..had around 40 to the pot and the reg on the gun was at around 5 to 10
    Apr 2009
    Outside the beltway
    5,259
    Can you use a cup gun ? The problem with the gravity feeders is you can not twist the gun into positioning it to get into corners as you move through the piece.
    17,474
    i have in the past,, maybe i need to go back there?? so what are the advantages on gravity feed gun??? i was told to use them because that was what i was taught on by some one with more knowledge than me at the time and still for that matter.. before that i had used a cup gun..maybe the cost was his reasoning???
    Apr 2009
    Outside the beltway
    5,259
    I can not tell you honestly because I have never used one. I took one look at the gravity feed gun and knew I could not get into places I needed to. I turn the gun side ways and for brief second upside down. But when I do that I need to do a serous cleaning job on the gun. It dose not happen often but when I need to the cup can handle it.
    4,552
    Larry I was taught to set the pot pressure (with no atomization air[kink the hose]) to make the fluid stream to squirt out about 2 to 3 feet in front of nozzle and that pressure will change with different viscosity of fluid.
    (what they really said is no further that you can pee) hope I didn't violate the CoC but that is what the big boys told me.
    This is what I was taught from the boys at Spray Equipment not sure if they are up you way or not.
    A Turn N Time
    Frog Pond Guitars
  1. How do I make a bushing smaller
    By Bob Gibson in forum General Woodturning Q&A
    Last Post: 12-19-2013, 04:24 PM
  2. New 'smaller' Crosscut Sled
    By Ned Bulken in forum Jigs and Fixtures
    Last Post: 01-01-2013, 02:40 PM
  3. Making my shop smaller...
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 12-11-2009, 04:09 AM
  4. couple of smaller bowls
    By Ken Easley in forum Lathe Project Showcase
    Last Post: 09-16-2008, 02:37 PM
  5. Smaller tree limbs for blanks?
    By Jim Zimm in forum General Woodturning Q&A
    Last Post: 05-20-2008, 11:54 AM
