Results 1 to 6 of 6
Thread: Supporting LARGE stock at the Drill press...
    London, Ontario
    3,383
    Just a quick post on a simple technique...
    I have a modest sized basement shop, so I'm wary of adding in anything that takes floor space. As such, I don't have any mobile outfeed supports (like this). Normally, that isn't a problem.
    Today I wanted to rough out some shallow mortises in the head+foot of a bed I am making, to accept the stub-tenons from the rails. I suppose I should have done this before I assembled the head and footboards... Oh well, live and learn.
    I considered a chisel, but that's too much work. I considered a hand drill, but feared it would be too hard to get consistent results. But my drillpress table is only about 14x20inches at best, which is way too small for this job! I needed some help.
    As I was looking about for something to use for stock support, I happened to notice that the fence on my jointer was almost the same height as my drillpress table. That'll work! I checked with the tape measure and adjusted the drillpress table to match the height. I draped a protective mat over the jointer fence, and set up the drillpress to make my mortises.
    Worked like a charm.
    11,825
    Ingenuity at work.
    Floydada, Tx
    1,941
    I like it. Anything that will work.
    17,470
    yup sometimes just a milk crate and few pieces of scrap wood to make the level right for wider support table..
    10,600
    Pretty ingenious solution
    30,002
    Looks like it worked great, Art. My lathe runs parallel with the outfeed from my bandsaw. When I've needed to resaw long boards, I've swung the lathe banjo out so it's in line with the bandsaw outfeed, then adjusted the tool rest to the same height as my bandsaw table. For as seldom as I have a need to resaw long lumber, it's just the ticket.
  1. Vee-blocks for drill press for round stock
    By David Agnew in forum Jigs and Fixtures
    Last Post: 08-06-2014, 02:20 AM
  2. Which drill press?
    By Paul Gallian in forum New Tools
    Last Post: 11-23-2012, 04:50 PM
  3. What about this drill Press?
    By Steve Southwood in forum New Tools
    Last Post: 12-24-2009, 01:05 PM
  4. New Drill Press
    By Vaughn McMillan in forum New Tools
    Last Post: 01-21-2008, 04:38 AM
  5. Drill Press - Drilling large hole over small hole or vise-versa
    Last Post: 12-26-2007, 10:13 AM
