Well, You'd better get some new carving chisels too. What's a cigar store without a cigar store indian?
Maybe you can get Toni to carve one for ya...
The more I think about this the more my brain hurts
OK, I do think that the doors should be overlayed, I can run a piece of weather stripping to seal them when closed, so this would be a good thing, yes when they are opened I loose a lot of the humidity, but that is just part of the way a commercial display cabinet works. I will have a fairly large humidification device with two fans to get things back to normal ASAP when the doors close.
I'm now thinking that >> these << look best, I like the 120 degree opening, gives me more room when the doors are open.
For the Overlay....
... I'm thinking 3/4" would be good, anyone see a problem with that? ???
I will make faceframe cabinets. I'll use the tall gang lock to lock the top cabinet doors, and an overlap of the two doors to keep both locked (if that makes sense).
Going with 4 hinges on each door on top, and of course two on each door on the bottom.
I really have to get this done, so I need to order this stuff soon, what do you think of my plan now?
For the Overlay....
