Results 1 to 5 of 5
Thread: Detailing cabinet
    Chris Hatfield is offline Former Member (by the member's request)
    Aug 2010
    380
    Detailing cabinet
    One of the first things in my shop remodel I need to do is to remove my tall detailing cabinet from the floor. It's something I re-purposed from in my house, and it's only being used because I needed something.
    A fairly good idea of what I'm referring to:
    What will be stored inside of it is my RO detail machine (think of an angle grinder), the pads for it (what is currently inside of that orange toolbox), various bottles of not too big of a size, and those spray containers. Spray containers may hang off of a bar below the cabinet, depending on how much I need to fit in there.
    For my design, I'm thinking of a side opening clamshell cabinet. Shelves deep enough on both sides to hold a single row of containers, about as big as a standard spray bottle. I don't want to store a ton in there, and my big containers of product are going to be kept inside so they aren't ruined when they freeze.
    Two questions - one is a recommendation on which hinges to use. I want ones that will allow the cabinet to open 180 degrees flat against the wall, and won't blink at the weight I'm putting in there (30lbs tops on the hinged section).
    The other is if there's anything I can line the inside with to get an insulating factor of about 10 degrees. If I can keep things from freezing inside the cabinet in most winters, I'd be happy. I figure even if it gets down to 15 outside, if I can get a 10 degree cushion inside the cabinet itself, I'll be okay.
    5,379
    Quote Originally Posted by Chris Hatfield View Post
    ...For my design, I'm thinking of a side opening clamshell cabinet. Shelves deep enough on both sides to hold a single row of containers, about as big as a standard spray bottle...
    I can't quite visualize what you mean by 'clamshell.' Can you explain a bit further?
    ...Two questions - one is a recommendation on which hinges to use. I want ones that will allow the cabinet to open 180 degrees flat against the wall, and won't blink at the weight I'm putting in there (30lbs tops on the hinged section).
    Depending on the height of the door, two, three, or four of nearly any 180į cabinet hinge will work. Three will likely work for any door less than 18 inches wide, and maybe 4~5 feet high.
    ...The other is if there's anything I can line the inside with to get an insulating factor of about 10 degrees. If I can keep things from freezing inside the cabinet in most winters, I'd be happy. I figure even if it gets down to 15 outside, if I can get a 10 degree cushion inside the cabinet itself, I'll be okay.
    Maybe line it with 1" thick foil-faced foam? You could also put a porcelain socket and a small light bulb near the bottom of the cabinet. The heat from even a small bulb - like a 25 or a 40 watt - would keep your insulated cabinet nice and warm.
    ďThe opposite of bravery isnít stupidity, itís conformity. Even a dead fish can go with the flow.Ē
    Roy Underhill, 2018
    Aug 2010
    380
    What I mean by that is, let's say the cabinet is 16" deep. Instead of a door on the front and a set of 16" deep shelves, the front of the cabinet opens and you have 8" deep shelves on either side of the hinges. Basically two cabinets hinged together.
    If I make the shelves where my product is only 1 container deep, everything is in easy reach.
    I'll have to find a different solution in the short-term aside from the bulb, as a permanent power supply out there is a good 2-3 years away, if ever. I'd rather take my kids to Disney.
    10,619
    Maybe a piano hinge in that case.
    5,379
    Yeah, as Bob said, perhaps a piano hinge, although three 3" 'butt' hinges would probably be sufficient. If you're ordering online, Woodworkers Hardware Has pretty good prices on piano hinge - and probably the butt hinges, too.
    Roy Underhill, 2018
  1. TV cabinet done
    By Bob Gibson in forum Flatwork Project Showcase
    Last Post: 01-03-2014, 02:41 AM
  2. Another cabinet
    By Steve Southwood in forum Flatwork Project Showcase
    Last Post: 06-04-2012, 03:32 PM
  3. TV Cabinet
    By James Lord in forum Flatwork Project Showcase
    Last Post: 07-13-2011, 11:39 AM
  4. New Cabinet
    By Don Orr in forum Flatwork Project Showcase
    Last Post: 02-07-2009, 04:23 AM
  5. cabinet
    By Roger Myers in forum Designs, Plans and Sketches
    Last Post: 02-06-2007, 05:38 PM
