Results 1 to 5 of 5
Thread: Lesson Learned - HVLP Turbine
    Livermore CA (SF Bay Area)
    51
    I thought I would pass on a lesson I learned today, in the hope that I am not the only idiot out here. (I probably am!)
    I have a Graco 4900 HVLP Turbine. It usually works very well, but today all it would do is spit and pee out of the needle. I changed to every needle and seat available and still spit and pee.
    A thought came to mind: "Go read the manual, idiot." It read: "Don't fill the cup more that 3/4 full, idiot!"
    In my desire to limit the times I needed to fill the cup, I had it pretty much full. I poured some of the paint out, and the spit and pee were gone.
    Anyone else out there ever gone through such lunacy? Please, someone. I hate to feel all alone and stupid.
    Thanks for letting me rant (at myself)
    Warren
    4,552
    Them pesky instruction
    A Turn N Time
    Frog Pond Guitars
    17,472
    nope wasnt me,, becasue i didnt have a turbine,, just a gravity feed gun with a compressor,, mine worked the night before and wouldnt the next mourning i looked all over and my manual never told me to read the idiot section.. so i called a friend and he translated idiot into common sense the vent hole was plugged// took a small nail opened the hole tried it again and then had to readjust every thing because i had cranked the pressure up to get it to work and got no where but frustrated.. now the vent gets checked each time i spray and its always cleaned out at the end of the term.. so yur not alone
    "i too am a idiot" and are taking pills for it
    Apr 2009
    Outside the beltway
    5,255
    I do not see the problem. I fill my cups all the time.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    5,321
    ...translated idiot into common sense the vent hole was plugged// took a small nail opened the hole tried it again and then had to readjust every thing because i had cranked the pressure up to get it to work and got no where but frustrated.. now the vent gets checked each time i spray and its always cleaned out at the end of the term...
    BT,DT
  1. Lesson learned, I think...
    By Roger Tulk in forum General Woodworking Q&A
    Last Post: 05-06-2012, 07:33 PM
  2. Another Lesson Learned
    Last Post: 01-16-2011, 04:26 AM
  3. lesson learned
    Last Post: 07-16-2010, 01:19 PM
  4. HVLP turbine guns
    By Chris Mire in forum Finishing School
    Last Post: 09-14-2008, 06:16 PM
